2011 ram 1500 5.7
Old Feb 18, 2025 | 08:27 PM
Braysmittey's Avatar
Braysmittey
Default 2011 ram 1500 5.7
So my front end is squeaking and I’ve already replaced the alternator, both belt and idler tensioner pulleys and a new dayco belt. There’s also a video do the noise it’s makin, anyone got any idea?
Old Feb 19, 2025 | 01:15 PM
SHO Rod's Avatar
SHO Rod
I'm unable to play that video back on my work computer, but with the belt off have you tried rotating the belt-driven assemblies to see if any of them feel rough or make a squeaking noise? Is the noise definitely related to the engine speed? Have you tried starting to the engine with the belt removed to see if the noise is present (and thus eliminating or confirming the issue is with a belt-driven component)?
-Rod
Old Feb 19, 2025 | 03:01 PM
fbrakeman's Avatar
fbrakeman
When you say front end... do you mean Engine or the actual Front end?
Old Feb 19, 2025 | 03:08 PM
fbrakeman's Avatar
fbrakeman
I agree with SHO Rod, remove belt, crank, hood open, you might could take mechanics stethoscope or extra long screwdriver to your ear (without hitting moving parts if any), and listen around to pinpoint sound.
Otherwise Water Pump, Fan Clutch, Alternator, A/C, Power Steering, belt tensioner / pully bearing, idler pulley, just to name a few.
Old Feb 19, 2025 | 05:48 PM
Braysmittey
-Rod
I removed the belt and started it and no sound. So it’s something belt driven
Old Aug 23, 2025 | 01:27 PM
fbrakeman's Avatar
fbrakeman
Hello
I once had a squeaky belt. I replaced it with a Goodyear Gatorback low noise serpentine belt and noise went away.
