BCM reset ?
Old May 20, 2025 | 07:02 AM
dodgeordie's Avatar
dodgeordie
Default BCM reset ?
hey guys is there a way to reset the Body control module everything seems to work other than the fog lights
i did replace a 40A [green] and a relay fuse checked the bulbs looked ok... what are the odds both bulbs went bad at the same time ? worked 1day the next they were out
any ideas ?
Old May 20, 2025 | 01:53 PM
SHO Rod's Avatar
SHO Rod
For starters, what model year is your Ram? Have you checked for voltage to the fog light bulbs and confirmed the ground to them is also good?
Do the switch and instrument cluster indicators illuminate when your switch the fog lights on?
-Rod
Old May 21, 2025 | 09:46 AM
dodgeordie's Avatar
dodgeordie
sorry Rod 2016 crew cab, clusters are working except when I switch to 1st position, thats fog and run lights indicator , 2nd position is headlights and run lights working , but no fog lights
have no idea where the grounds are and not sure i have anything to test them with
Old May 21, 2025 | 01:52 PM
SHO Rod's Avatar
SHO Rod
Unless they've greatly changed the function of the switch between the 2014 and the 2016, the fog lights are activated by pushing in the headlight switch (or is it pulling out?), not just by rotating the headlight ****. Factory wiring should only enable the fog/driving lights to work when the low beams are on. I'm pretty sure they won't activate with just parking lights or when the high beams are selected.
Do you have an owner's manual so that you can confirm the proper activation and operation?
-Rod
Old May 22, 2025 | 07:18 AM
dodgeordie's Avatar
dodgeordie
i"ll check the headlight **** i always rotated the light switch and they came on
Old May 22, 2025 | 10:12 AM
dodgeordie's Avatar
dodgeordie
Morning Rod
Well if i wasn't such an idiot i could of read the tiny writing on **** that said push...guess what they work lol
i probably inadvertently push them off when i was dusting all the green dust off the dash, never happened in the 7 years I've owned the truck.
Thank you !
Old May 22, 2025 | 11:09 PM
SHO Rod's Avatar
SHO Rod
Awesome, glad to hear you got it figured out and it's not an issue with the truck. Thank you for following up with what you discovered. Well, maybe not the idiot part.
-Rod
Old May 28, 2025 | 07:41 AM
James (3rd Gen 5.7)'s Avatar
James (3rd Gen 5.7)
any ideas ?
Hello.. I've got a 2010 Dodge Ram Laramie, and Dodge Charger, that I was able to reset the BCM with by using a bidirectional scan tool. Mine is the ThinkScan 689BT from Amazon. I needed it for the OEM dealership software and didn't want to have to pay a subscription for something just to be able to reprogram an ABS module and mess with some fog lights.
Edit: I was also able to enable the DRL lights.. which are set to disabled by default.
