Chrome Clad Wheel Replacement
Old Aug 20, 2025 | 09:39 AM
jawsdc's Avatar
jawsdc
Default Chrome Clad Wheel Replacement
Has anyone had any luck with changing the 09-12 chrome clad wheels to another OEM wheel?
My bolt pattern is 5-127 but most of the other 5 bolt Ram wheels I'm finding are 5-139.7
Old Aug 20, 2025 | 06:15 PM
Are you measuring it properly? ALL of the 1500s should be using the same bolt pattern..... (or similar weight rating if your ain't a 1500.....)
Old Aug 21, 2025 | 08:51 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
All 1500's use the same bolt pattern from 1994 to the end of the Classic run in 2023; 5th gen starting in 2019 uses a six lug. Any 17"-20" wheel from 2002 on is forwards and backwards compatible. I would avoid the mid 4th gen chrome clads as they are only 20x8 vs 20x9 that all the others are:
Old Aug 21, 2025 | 08:59 AM
dodgetruck2's Avatar
dodgetruck2
Agreed, any 17" Ram OEM wheel is compatible with all 5 lug Rams since the change, I thought 5x5.5 started in the late 80s already but I'm not going to argue that part. Just note it needs to be a 17" to clear the brakes.
Old Aug 21, 2025 | 09:50 AM
jawsdc's Avatar
jawsdc
Factory OEM WheelDodge RAM 1500
Wheel Size20x9
Bolt Pattern5-127
FinishMachined Chrome Clad
Old Aug 21, 2025 | 10:05 AM
jawsdc's Avatar
jawsdc
That's the wheels on my truck (above)
This is an example of ever other 20" 5 bolt wheel (below)
Factory OEM Wheel
Dodge Ram 1500
Wheel Size20x9
Bolt Pattern5-139.7
FinishPolished Silver
Old Aug 21, 2025 | 10:20 AM
Are those from ads? I would suspect that one is a misprint...... Have you measured the bolt pattern on your wheels?
Old Aug 21, 2025 | 10:29 AM
jawsdc's Avatar
jawsdc
I haven't measured the bolt pattern but the info is the same on multiple websites. I'm trying to avoid paying a hundred+ dollars a pop for yard art.
Thanks for the feedback
Old Aug 21, 2025 | 10:44 AM
I'd be tempted to pull one of your wheels, and physically measure the bolt pattern....... So far as I know, ALL of the 1500's used the same pattern......
Old Aug 21, 2025 | 11:08 AM
jawsdc's Avatar
jawsdc
