2010 Ram Fuel pump replacement issues
Old May 1, 2026 | 12:40 PM
KenStauss's Avatar
KenStauss
Default 2010 Ram Fuel pump replacement issues
I recently had to replace my fuel pump. Had to drop the tank and cracked the line that feeds "overflow" fuel back to the tank. I'm assuming that's what it does since it connects to the hole in the fill pipe at the top. I tried to repair it to no avail. I left it disconnected. Now I have an issue with extremely slow fuel filling. I can't imagine that line would cause that problem. It's like it gets enough gas into the fill tube, then shuts the pump off. I have to wait a few seconds before I can do it again. 20 minutes to get a half tank. I checked the charcoal box air flow, and it seems fine (passes air without restriction. Replaced the esim valve, and my reader shows it opening and closing. I replaced the fill hose, thinking that it may have collapsed just enough to cause the problem. still no joy. I also checked the anti-syphon valve, and it appears to be working correctly. Any ideas would be greatly appreciated. Thanks
Old May 1, 2026 | 02:58 PM
That's a vent hose, and without it, you run into exactly the problem you are describing. Need to replace it. Local parts store likely has the appropriate hose in bulk.
Old May 1, 2026 | 03:26 PM
KenStauss's Avatar
KenStauss
youre are right that its a vent hose but not one they have in bulk. The line is the pressure type connectors and a hard plastic line. The part that brok is actually the nipple on the tank. The only way to "correctly" fix it is a new tank. That part is not sold. thanks for the info
Old May 1, 2026 | 09:54 PM
Could you epoxy, or plastic weld it back together?
