Rain drops falling on my head. Sunroof leak?
Old Nov 18, 2009 | 04:10 PM
  #31
MattsMountain's Avatar
MattsMountain
Default Leak update ...
After 4 days of my truck in the shop, it was not the drain tubes. They found water was coming in through the seal, making it's way to a spring tensioner, getting on the sunroof track and making it's way in to the roof.
I'm not entirely sure what they did to fix it, aside from a new seal. We'll find out in the next rain I guess.
I wasn't the only truck in the shop with this problem .. 6 others with the same issue. Guy told me it was a sunroof manufacturer defect - whatever that's supposed to mean.
Best of luck,
Matt
Old Nov 18, 2009 | 11:11 PM
  #32
09RAM4WD's Avatar
09RAM4WD
i have the sunroof, it was a must have for me, no problems with it yet though...hopefully stays that way
Old Nov 19, 2009 | 04:34 PM
  #33
topgun's Avatar
topgun
Ditto. I just wish it opened the whole way like my last truck. The service manual says it should but nothing happens when you press the button a second time.
During express opening, the sunroof glass panel will first open to the “Comfort Stop” position. A second press of the “OPEN” button on the rocker switch will move the glass panel to the full open position.
Old Feb 28, 2010 | 06:04 AM
  #34
Topsy's Avatar
Topsy
Default Sunroof leak
Hi
I am new to forum
can anyone tell me where I find the sunroof drainage holes on a Chrysler neon as I cannot see them?
Old Apr 25, 2010 | 09:24 PM
  #35
idesigncabinets's Avatar
idesigncabinets
I have an 2006 Laramie that I special ordered from the factory. The friggin sunroof started leaking from the "Oh Crap" handles on both sides. I had to bring it to the dealer two times before they even found the leak. The fix lasted a while and now I found out that the extended warranty doesn't cover it. Don't get me wrong, I love my truck but it was a big mistake ordering it with the sunroof. You would think that they would be able to build a truck that doesn't leak, especially after dropping 35K on it! I mean wft? If I could turn back time I would have done my best to keep a close eye on it and try to qualify for the lemon law. So if your truck is very new, you might consider this. Then buy a truck without the sunroof. I'm going to try some clear caulk or silicone and just lock it shut. Any advice on what will work the best? I don't want to play games with unclogging the hoses and such. Thanks in advance and the oppurtunity to vent, lol!
Old May 21, 2010 | 03:53 AM
  #36
jjjjhh's Avatar
jjjjhh
Default Sunroof Drain Tube Clogged
My Durango had water draining into the fusebox during unusually heavy rain. Found the sunroof drain hole clogged on the driver's side. Cleared drain hole of debris. Blocked drain hole and poured water in drain trough to see where water would go if the hole was clogged. As soon as the water got to a certain level, it spilled into the sunroof track seam, it immediately started leaking into A-pillar and into fuse box area. I've attached some pics of the drain hole and track seam area as well as the normal location that water exits when the drain is unclogged and also one of the fuse box. This forum helped me diagnose the problem, so I thought it might save some others some time, money and headaches if I posted some pictures.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 28, 2010 | 09:41 AM
  #37
cranshaw's Avatar
cranshaw
Default I had the same problem
Originally Posted by Mepsgod
I am bumming, truck still at dealership. They said they can't find the leak yet. I will let it stay there until they can find it and get it fixed. We have three days of rain on the way in Eastern North Carolina. I would rather have it in their bay than leaking in my driveway. Wish me luck and hope they find it and fix it soon, I am having withdrawal pains. Driving a 2001 Grand Caravan is just not the same as driving the truck with a Hemi and the other goodies in it. Don't get me wrong, I have no problem looking like someones dad driving this thing, but I like the truck better. So do my three boys.
I bought a dodge 2009 Crew Cab Big Horn Edition february of 2009, it has a sunroof. Stickered at almost $48,000.!! It leaked a couple months after owning it. i ended up taking it in 7 times for the same problem. Water in front of my shifter compartment leaking from the overhead counsil and Water collecting in my floor mats dripping from the OH SH#T handle. First they said they found a kinked hose, then they adjusted the sunroof 3 different times. Last they said they found some service bulletin that showed new adjustments for the glass, more precise. I was so fed up I contacted Chrysler Corporate, a local news paper, i even had a specialist come to the dealer ship to run water over it with a hose and he couldn't find anything. I tried for the Lemon Law and it failed!! After the last adjustment it didn't leak for about 4-6months and then I got in the truck one day and there's water streaming out of my Oh Sh#t handle again 5/10/2010. I have 5,700 miles on my truck and the only thing I've seen so far that I never heard the dealer ship mention was maybe the rear break light is leaking but I highly doubt it. I basically am just fogetting about it, I don't think they know what the F#$%'s wrong, I wanted a new truck but they refused to go that easily. If they would let me do it again I would have never got the dang sunroof!!
Old May 28, 2010 | 02:24 PM
  #38
72combo's Avatar
72combo
Probably why the trucks are on hold at the plant, or some of them..
Old May 29, 2010 | 12:53 PM
  #39
Big Black Beauty's Avatar
Big Black Beauty
Default Sunroof alignment
My sunroof appears to have the issue of needing adjusted. The sunroof goes through the motions of closing correctly, but it is an 1/8" below the roof line. Is there a way to adjust the motor or alignment when closed?
Old May 29, 2010 | 01:48 PM
  #40
Big Black Beauty
Default Never Mind
Trial and error. Dropped headliner. Then found there was adjustment in the 4 screws holding the sunroof on (didnt need to drop headliner for this adjusment. Just remove the plastic decorative accordian fan pieces by slipping them off.) Adjusted the rear screws but still came up short by a 1/16".
Almost screwed myself by starting to take the motor apart.
Dropped entire motor assembly to allow the sunroof brackets freedom to move. Slid them until the sunroof sealed.
Remember, as per other threads, make sure the sunroof is already in the closed position!
Good thing about dropping headliner, I was able to remove all of the leaves stuck between the roof and headliner. Also was able to access the rear drain tubes and blew them out.
Hope this keeps others from doing hit and miss on adjustment and saving some $ at repair shops.
