5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Let Everyone Notice Your New Ram 1500 With Bright LED Turn Signals
Old Aug 22, 2023 | 09:56 PM
LASFIT's Avatar
LASFIT
Former Vendor
Default Let Everyone Notice Your New Ram 1500 With Bright LED Turn Signals
The all-new fifth-generation 2019 Ram 1500 truck has made a lot of noise. And, for good reason.
It has a ton of improvements and enhancements that really help it stand apart from the competition. That’s part of the reason why you might be considering one, or already own one. The Ram 1500 feels like a complete truck with not many areas left for improvements.
That’s unless you’re known for modifying your vehicles. In that case, there’s always something to improve. That’s what modifying is all about.
For the Ram 1500, one of those areas is lighting. The Ram 1500 demands attention during the day, but at nighttime, it’s a different story. The OEM halogen bulbs leave a lot to be desired, and don’t command the attention the new 2019 Ram 1500 deserves.
If you want to be seen at all times, then there are some worthwhile LED bulb upgrades to be made. Here we’ll talk about the best LED turn signal bulbs for the 2019 Ram 1500. These bulbs will ensure everyone around you knows your Ram 1500 is about to make a turn. And, that’s exactly how it should be.
Lasfit is a trusted name in the automotive LED bulb community. With our experience, we’ve been able to create a LED turn signal bulb called the T-Series. They function wonderfully and fit the new 2019 Ram 1500 like a glove.
What should you expect? You should expect what you want, and that’s a bulb that allows other drivers to see you better at nighttime. A LED bulb that will enhance the visual appearance of your truck. Offers an easy installation process. It is completely compatible with your Ram 150. Lastly, offers a great-looking switchback option, if you choose that route.
Let’s dive into each feature of the Lasfit T-Series LED turn signal bulb.
One of the most important features is the easy-to-install nature of the T-Series LED turn signal bulbs. You don’t need to call up your friend for help. You can do the installation in the comfort of your driveway or garage with zero headaches. We kept it as close to the OEM halogen bulb as possible, and that means you don’t need to cut or splice any wires. Forget about installing additional resistors or other parts. You’ll save time by going with these LED turn signal bulbs.
Our goal was a plug n’ play LED bulb, and that’s precisely what you can expect. This bulb is polarity protected, so if the bulb doesn’t light up all you need to do is turn it around and reinstall it. Simple.
A common issue associated with LED turn signal upgrades is hyper flashing. This occurs alone, or sometimes it’s accompanied by an error light on your gauge cluster display. This is an annoying issue that’s the result of the LED bulbs tripping the vehicle computer system. The solution has always been a bit complicated.
The solution has always been to install an external resistor or relay. The problem is, the external resistor can be challenging to install for a number of reasons. First, it requires cutting and splicing wires. Second, the external resistor gets so hot that you need to be careful where you bolt it to. You can’t leave it hanging, because it can easily melt through wires and plastic. That’s very dangerous.
Our solution was to create a LED turn signal bulb that features a built-in resistor function. It works perfectly with the vehicle computer system (CANBUS). The results are LED turn signal bulbs that rarely cause hyper flashing, nor error code lights to pop up on your gauge cluster display, and don’t require the need to install an external resistor.
LED turn signal bulbs are not only about looks but also safety. Improving the safety of your truck is always a good thing. Changing lanes will be safer because of the LED bulb’s brightness. The Lasfit T-Series LED bulbs are 300% brighter than the OEM halogen bulbs. Their brightness allows other drivers to see you easier. 6000K for the vivid white parking lights and 3000K for the amber lights. They’re hard to miss at night!
Of course, the ability to express your own style is available because of the switchback LED turn signal bulbs. If you decide to go with pure amber, then both your parking lights and turn signals will be bright amber. If you decide to go with the switchback option, then your turn signal will be in amber while the parking lights will be in pure white. When you turn the signal on, it will switch between both. You can’t go wrong with either look.
Automotive LED light bulbs run hot, and there’s no way around it. We didn’t want to jeopardize the lifespan of our T-Series LED turn signal bulbs, so we added a new technology called ITCS (Intelligent Temperature Control System).
Here’s how it works.
If you leave your turn signal on for over 5 mins, then the LED will generally begin to get very hot. That’s when the ITCS will kick in and warn you to cool off your bulbs. The method it uses to warn you is by hyper-flashing your turn signals. So, if you notice your turn signal lights begin to hyper-flash, then that’s a sign they are reaching very hot temperatures. Don’t worry, they aren’t broken. To solve the problem all you need to do is turn them off for a few minutes and they will go back to working like normal once you activate them again.
Hopefully, you don’t need to experience hyper flashing very often because we went the extra distance to include 4 small cooling holes, and a special aviation aluminum structure to improve heat dissipation. This alone should keep your LED bulbs cool, except for those rare occasions when you forget to turn them off because you’re playing your favorite song too loud. It happens to all of us at least once.
The fifth-generation 2019 Ram 1500 is a great truck. They did an awesome job anticipating everything their customers would want in the all-new 2019 model. But, as modifiers, you know there’s always room for improvement. With the 2019 Ram 1500, that’s the OEM halogen bulbs. Luckily for you, Lasfit has all the LED light bulbs you could want.
Note: Due to the different factory socket designs, please double-check before ordering the LED lights.
#T-3157D LED bulbs for 2019-2020 Ram 1500 Classic front turn signals:http://www.lasfit.com/products/3157-...13865930752084
#T-3157D-CK LED bulbs for 2019-2020 Ram 1500(Not Classic) front turn signals:http://www.lasfit.com/products/3157-...21394795528276
