5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
2019-2021 Ram 2500 3500 LED Upgrade Bulb Size Guide
Old Nov 20, 2023 | 09:22 PM
LASFIT's Avatar
LASFIT
Former Vendor
Default 2019-2021 Ram 2500 3500 LED Upgrade Bulb Size Guide
Hello everyone, it is an absolute honor to be here introducing Lasfit LED bulbs to the owners of Ram 2500/3500. We are genuinely concerned about providing users with the best experience, particularly addressing the issues of dim lighting and shortened bulb lifespan. As a result, we have upgraded our LED bulbs to ensure optimal visibility while driving your Ram 2500/3500 at night, effectively eliminating the need for frequent headlight replacements and saving you money in the process.
Besides, Lasfit offers a wide range of LED bulbs specifically designed for Ram 2500/3500. With LAplus, you can enhance the brightness of your night driving, ensuring safety on the road. We also have a special CK problem-solving turn signal to address any turn signal or strobing issues you may encounter. Additionally, we offer LED bulbs in the correct sizes for your dome lights and cargo lights.
Product Spec
Low Beam: LAplus H11
High Beam: LAplus 9005
Each bulb of LAplus H11 or 9005 is designed to provide 30W and 3000LM, making them brighter than halogen bulbs. With a bright white light of 6000K, they ensure clear visibility on dark roads. The 360° adjustable socket allows for easy beam pattern adjustment according to your preference. Moreover, their interior driver and shorter size make them convenient to plug and play.
Fog Lights: LAplus H11
LAplus fog lights provide a super high brightness of 60W and 6000LM, eliminating concerns about visual blurring during rainy night travels. The 6000K white light can even penetrate fog, allowing for a safe driving experience. The 360-degree adjustable bracket allows for free adjustment of the light beam, while the smaller size makes it easy to insert the LED bulbs into the fog light assembly. The IP67 waterproof and dustproof configuration, along with an enhanced heat dissipation system, ensures a longer lifespan for the fog lights.
Other Front Exterior LED Lights
Front Turn Signal Lights: T-7443D-CK
For the T-7443D-CK, owners can enjoy a configuration of 24W and 2400LM, providing ample brightness for various lighting needs. It is equipped with a convenient switchback function, providing users with both Amber and White lighting options. The 6000K white lights can be used for parking lights or daytime running lights, while the 3000K flash amber option is perfect for turn signal lights.
Rear Exterior LED Lights
Rear Turn Signal Lights: T3-3157A
Lasfit just released the new 3157 rear turn signals, 24W, 2000LM brightness, brighter but softer output, and compact size that you put the bulb into the housing with ease. With a built-in decoder system, its decoding capacity has improved. Moreover, the upgraded cooling system makes the bulb more durable. All you can get from this new release for the Ram 2500 3500 rear turn signals.
Brake/Tail Lights: T3-3157R
We have new brake/tail lights available for the Ram 2500 3500, similar to rear turn signals. These lights have a power output of 24W and a brightness level of 2000LM, ensuring that anyone behind you can clearly see when you are braking. Additionally, these lights are equipped with a built-in micro decoder and an upgraded cooling system, making them stand out in terms of design and functionality.
Backup Lights: L-7443
The L-7443 is designed to provide a total output of 1200LM per set, making it suitable for the Ram 1500. It is capable of emitting a bright white light at 6000K, enhancing visibility for the rear of the vehicle during reverse maneuvers. Additionally, these bulbs are canbus friendly, ensuring compatibility with the vehicle's electrical system.
Cargo Lights: L-T15
3rd Brake Lights: L-T15R(Red)
The Lasfit L-T15 bulb is designed to provide a bright output of 1400LM per set, ensuring sufficient brightness to alert vehicles behind you. Moreover, you can rest assured about compatibility issues as it is canbus supported, reducing the hassle of flickering lights.
License Plate Lights: L-T10
The L-T10 series features 3 bright 3030 lamp beads that can provide 800LM of brightness for the 2019-2021 Ram 2500/3500. With its 6000K white light, it can effectively illuminate the rear license plate, ensuring clear visibility. The 360° lighting effect ensures that no area is left in darkness, providing ample lighting for vehicles approaching from the rear.
Interior LED Lights
Dome lights: L-44MM
The L-44MM festoon bulb from Lasfit is equipped with 8 3030 SMD LED chips, providing an extremely bright 6000K white light. It features an Efficient Aluminum Heatsink System, which enables the LED bulbs to dissipate heat effectively, thereby extending the lifespan of the headlights.
Map Lights: L-T10
The L-T10 interior light from Lasfit is a versatile option that can be installed in various locations on different vehicles. For the Ram 2500/3500, it can be installed as a map light. The L-T10 features a non-polarity design for easy plug-and-play installation, ensuring an error-free experience. With a configuration of 800LM per set, it provides superior brightness compared to the original halogen lamp.
Additionally, the L-T10 series offers a range of color options, including white, yellow, blue, and green, allowing you to customize your footwell lights according to your preferences and needs.
Customer's Feedback
The following contents and pictures are authorized by our customers, many thanks to them!
Case1
Absolutely stoked on these LED bulbs. The truly are plug and play and the quality is unmatched. I’ve put Lasfit’s lights in all of my vehicles.---A.F.
Case2
I ordered all the exterior front bulbs, low and high, fogs & sequential turn signals. Bulbs put out great light and are truly white. I had a problem with the turn signals flashing to fast, emailed them and got another set sent out and they worked great! Good customer service with quick a quick response.---J.G.
Case3
I bought the whole package, every thing was plug and play. Super simple install. Love the way they look on my ram 2500. The foglights where flickering, sent them an email and sent me a replacement immediately. Great customer service. Definitely recommend.---m.m.
If you have any problems with mentioned LED bulbs, feel free to leave a message!
