5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Lift/Leveling kit for 2019 RAM 1500 5.7L
Old Dec 2, 2024 | 10:00 AM
racerxv6's Avatar
racerxv6
Default Lift/Leveling kit for 2019 RAM 1500 5.7L
So I am looking into adding some sort of lift/leveling kit for my 2019 1500. I recently put new tires on and went up in size by by one. I now have a rubbing when I make tight turns. I would like to lift /level the truck. What is the best solution for this from a mechanical standpoint and what would be the worst? Should I do just pucks, should I go with RC spring/shock combo? Just want to get some ideas not sure if I can get away with just pucks or I need to replace combo spring/struts, possibly the A-arms as well.....
Old Dec 2, 2024 | 10:21 AM
If you only want an inch or two, spring spacers would likely do the trick, may not even need to upgrade the shocks. However, depending on WHERE the tires are rubbing, a lift may not do anything at all for ya.
