5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Headlight Replacement - 2020 Laramie Longhorn
Old Oct 21, 2025 | 02:14 PM
pancholvr's Avatar
pancholvr
Default Headlight Replacement - 2020 Laramie Longhorn
I have a 2020 RAM Laramie Longhorn 1500. I was told I need to change the entire headlight unit on the passenger side since the low beam bulb went out. Is there any way around this? Has anyone figured out how to replace the bulbs? If I do need a new headlight unit, are there any good secondary sites you recommend?
Thanks for the help!
Old Oct 22, 2025 | 06:14 AM
wheily's Avatar
wheily
the bulbs are replacebole. just a pain in the butt ..if i remember right they use a 9005 bulb
Old Oct 22, 2025 | 06:58 AM
Check you tube
