5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Flashing Start/Stop Ignition - Truck Won’t Start
Old Dec 22, 2025 | 12:31 PM
Speedineden's Avatar
Speedineden
Default Flashing Start/Stop Ignition - Truck Won’t Start
Need some help diagnosing my 2021 dodge ram 1500. The ignition has a slow flash. Brake petal is hard and the horn sounds like a sick duck. I replaced the battery and the battery in my fob. Pressed the fob to the ignition and still nothing. The screen is black, no signs of life. Is this electrical or mechanical? I thought maybe something to do with the Uconnect radio or something with the starter or fuel pump? Need your help!
Old Dec 22, 2025 | 01:16 PM
Recheck your battery connections, make sure they are clean and tight. Also, might consult your owners manual, and see what it has to say about it.
Old Dec 22, 2025 | 01:35 PM
Speedineden
No corrosion, everything is clean but thank you
Old Dec 23, 2025 | 12:43 PM
Larrybomber83's Avatar
Larrybomber83
I would check to see if you had any updates that were cut short for whatever reason. I had not started my truck for a couple days and it would turn on the flashers and honk the horn until some update was done. Try that.
