Notices
lift level kit
Old Jan 4, 2008 | 08:55 PM
ram1500slt4x4's Avatar
ram1500slt4x4
Default lift level kit
I HAVE A LIFT AND LEVEL KIT NEW IN THE BOX MADE BY TRUXX I WAS GOING TO INSTALL THIS ON MY TRUCK BUT I CANT FIND ANYONE WILLING TO DO THE JOB
Truxx 2-3" (Adjustable) Leveling Kit ***Includes new shock relocation brackets!!!***
Dodge Ram 1500 4X4 2002-2005
Description
ยท 100% made in the USA.
ยท Allows fitting of up to 33" tires without trimming or rubbing (on some trucks you can fit 35" tires, 315/70 x 17, with stock off set style custom wheels (test fit as every company uses a different measuring tape).
ยท Each kit contains two torsion keys, shock relocation brackets, bolts, nuts and washers full color instructions and complete alignment specs.
ยท Increases ground clearance over traditional bracket type lift kits even without the use of larger wheels and tires for those interested in getting the most out of there truck for recreational or construction use.
ยท The shock geometry is corrected with the included brackets, ensuring that the initial stroke of the shock is not impeded.
ยท 2"- 3" lift (adjustable) with NO CHANGE in OEM ride quality, we have changed the key positioning to an optimized mathematically engineered and road tested design.
Can be installed with an OTC7249 Ball Joint Press and common hand tools.
Retail Price: $297.00 ASKING 100 PLUS 15 FOR SHIPPING i can do pay pal
Old Jan 6, 2008 | 05:08 PM
moparmutt's Avatar
moparmutt
Default RE: lift level kit
PM sent
Old Jan 6, 2008 | 06:04 PM
ram1500slt4x4
sold to moparmutt will ship monday
