00 RACE BUILT PLYMOUTH nEON!
CLICK HERE FOR CARDOMAIN PAGE
SPECIFICATIONS
Vehicle
2000 Plymouth Neon
Model
ES Sedan
Engine Type
2.0L SOHC 16 Valve Inline Four
Modifications
Clevite 77 Rod Bearing Set
Clevite 77 Main Bearing Set
Total Seal Piston Rings
Mopar Oil Pan Gasket Set
Melling Oil Pump
Eagle Specialty Forged Rods
JE 8.6:1 Turbo Pistons
8 Intake Hyrdraulic Roller Rockers
4 Exhaust Hydraulic Roller Rockers
Dayco Timing Belt
TTI Racing Low Compression Head Gasket
Mopar Gasket Set
Crane #12 SOHC Cam
Fidanza Adjustable Cam Gear
Crane Valve Springs and Retainers
Fast Fabrications Custom Intake Manifold
2 Lorenzo fuel rails
1 Lorenzo 60mm Throttle body
Phenolic Gasket Set
AF/X Underdrive Pulley
Morrosso Oil Pan
Fast Fabs dogbone eng/trans. Mounts
Deyeme Radiator Brackets
Power Adders
Custom T-3/T4 turbo (60 trim)
21/2 inch piping
Custom Front Mount Intercooler
3" fast fabrications down pipe
Turbonetics blow off valve
40mm Delta Wategate
Nitrous Express wet system
Blow down tube
Bottle Warmer
Purge
50 - 200lb jet sizes
Exhaust
Fast Fabrications
Tubular Exhaust Manifold
3" straight through mandrel bent pipe
from the down pipe back (no cat)
Apexi N1 Turbo muffler
3" inlet 5" outlet
Transmission Type
31TH Automatic 3-Speed
Modifications
Reverse Manual Valve Body
Shift Kit
Differential Gears
High Stall Torque Convertor
Top Quality Seal and Gasket Set
Red Eagle Band
Forward and High Gear Friction Plates
Extra Plates to increase Clutch Capacity
Kolene Steel Clutches
New Bushings
Stage 5 Driveshaft Shop Axles and Hubs
Phantom Grip Limited Slip Differential
CHASSIS
Suspension, f/r
Mopar X-high Rate Springs
Kyb struts
Energy suspension bushings
Mopar performance
sway bar set 19 and 22mm
Deyeme Racing lower lateral llinks
Tires
24.5x9x13 Hoosier slicks
17"adr RS competition wheels
Yokohama tires
EXTERIOR
Body
Lightened Xenon Body Kit
CF altezza taillights
Clear Headlights
Lighted Spoiler
INTERIOR
Gutted
Kirkey one piece light weight racing seat
RCI 5 point harness
Autometer phantom series gauges
(oil temp, oil pressure, water temp,
voltmeter, air/fuel, boost, fuel pressure,
exhaust gas temp, etc.)
Fast Fabrications 10 sec. Roll cage
Firewall for Fuel Cell
Greddy Profec digital boost controller
CLICK HERE FOR CLASSIFIED AD
PLEASE EMAIL ME WITH ANY INQUIRIES -- jb420456@yahoo.com
SPECIFICATIONS
Vehicle
2000 Plymouth Neon
Model
ES Sedan
Engine Type
Modifications
Melling Oil Pump
Dayco Timing Belt
Mopar Gasket Set
Crane #12 SOHC Cam
Phenolic Gasket Set
Morrosso Oil Pan
Power Adders
21/2 inch piping
40mm Delta Wategate
Blow down tube
Bottle Warmer
Purge
Exhaust
Fast Fabrications
3" inlet 5" outlet
Transmission Type
Modifications
Shift Kit
Differential Gears
Red Eagle Band
New Bushings
CHASSIS
Suspension, f/r
Kyb struts
Mopar performance
Tires
Yokohama tires
EXTERIOR
Body
Clear Headlights
Lighted Spoiler
INTERIOR
Gutted
RCI 5 point harness
