FS Dodge Exhaust Brake (Jake Brake) --NEW--
For Sale: Dodge Exhaust (Jake) Brake $1000.00
This was purchased for my 2005 CTD 6spd manual truck that I traded.
Never installed all parts New in Box
---Have one on my New truck & This helps get it warmed up Waaay quicker---
Description from site:
DIESEL EXHAUST BRAKE; FOR 5.9L CUMMINS TURBO DIESEL ENGINES. FOR USE ON 2005-2006 MANUAL TRANSMISSION AND 2006-2007 AUTOMATIC TRANSMISSIONS.
The new exhaust brake utilizes updated power train software to maximize torque converter lockup performance and to protect the Dodge Ram 48RE automatic transmission, and eliminates the need for an external lockup box. This results in up to 170 retarding horsepower to provide enhanced vehicle control and increased service brake life.
Jacobs Exhaust Brake is jointly engineered and tested by the Heavy-Duty experts at Dodge, Cummins and Jacobs Vehicle Systems to deliver superior performance.
The benefits of getting the best brake for the best engine include:
Increased vehicle control, especially for peace of mind when towing.
Reduces brake wear.
Your service brakes can last up to three times longer.
Helps your engine reach operating temperature twice as fast, while helping you conserve fuel after the warm-up process, when you start the engine and idle with the exhaust brake in the "on" position.
Has a shifter-mounted control switch which allows for easy fingertip control.
Includes a drilled and tapped port for installation of an optional pyrometer.
Compatible with vacuum-operated braking systems on many trailers.
Reduces brake wear.
