Notices
FS: 02 Dodge Ram 1500 408 Stroker - Waynesboro VA
Old Nov 2, 2009 | 04:12 PM
Lucas_Harman's Avatar
Lucas_Harman
Default FS: 02 Dodge Ram 1500 408 Stroker - Waynesboro VA
Means of Contact: laharman@comcast.net, private message, or cell 540-910-1824.
Description – 2002 Dodge Ram 1500 Sport
Price: 12,250 OBO
Pics – See below
Up for sale is my 2002 Ram 408 Street Rod…
A brief background on the truck…
I purchased this truck at the very beginning of this year with the 408 stroker but it had an oil pressure problem. I bought it, pulled the engine and had my local performance machine shop go through it with a fine tooth comb. We discovered the bearing clearances were way out of spec on the mains and rods. We ended up going with oversized bearings to cure the oil psi problem. While it was there the block was hot tanked, honed, new freeze plugs etc etc. Crank was professionally turned and balanced as well.
This truck is a beast to say the least, with a very long list of mods. I’ve broken them down below, but I am sure I am forgetting something here or there. It hasn’t been dyno’d or raced since the rebuild. Currently has about 300 miles on it since the rebuild with that number climbing daily. I am driving it to and from work in it everyday. If I had to guess I’d say its touching 450hp, but that is just speculation. I know it is almost impossible to keep traction on any kind of wet surface. 
Why am I selling?
This truck is a total case of a boy and his toy, it’s a blast and I love it but I have a wife and son and I really just need something a bit tamer with more room, either extended cab or quad cab. So yes I am open to trades depending on what you got. The truck is very loud, very obnoxious and everyone around my town LOVES it. I get 2-3 compliments a day on its looks and its sound. It is a real head turner, as you hear it coming before you see it 
The truck itself:
2002 Dodge Ram 1500 Sport Single Cab Short Bed
VIN 1D7HU16Z82J221187
Originally 5.9 Magnum
4x4 Auto
PW, PL, Cruise, CD w/ infinity sound system
Sliding Rear window
89,000 miles on chassis.
Anyhow, enough babble, hear is the mod list…..
Engine – 2002 360 stroked to 408
Eagle 4” Stroker Crank
Eagle Rods
Ross 10.5:1 Pistons .030 over
Clevite Main and Rod Bearings
Durabond Cam Bearings
ARP Head Studs
All New gaskets
EQ Magnum Heads Stage 3 fully ported/polished by FBO Systems.
Racer Brown Roller Rockers 1.6/1.5 Ratio
Trick Flow Push Rods
Racer Brown Cam (.544 Int/.510 Exh)
Comp Cams Double Roller Timing Chain
Mopar Timing Chain Tensioner
Melling High Volume Oil Pump
Mopar Magnum Valve Covers
Mopar .600 Lift Valve Springs
Mopar Chromoly Retainers
Mopar M1 4bbl Intake Manifold
Mopar 4bbl to 2bbl Adapter
K&N FIPK and K&N Air Hat (air hat for ram air)
Accel 24lb/hr injectors
Hughes Performance Stage 3 PCM Reflash
Drivetrain:
4x4
Transgo Shift Kit
Custom Valve Body
Dynamic High Stall Converter
4.56 gears front and rear
Detroit True Trac limited slip
All synthetic fluids
Suspension/Brakes
Ground Force Flip Kit
Drilled and Slotted Rotors
Traction Bars on rear leaf springs
Urethane Bushing Kit
Swaybars
Exhaust
JBA Headers with ball flange restrictions removed
Custom 3” exhaust
3” Y-pipe
3” Hi Flow Cat
Flowmaster single 3” inlet/dual 2.5” outlet dumped in front of rear axle
Exterior
Street Scene Front Bumper Cover
SRT10 hood
06+ Tailgate lip
Tonneau Cover
Steel Roll Pan
Interior
B&M Ratchet Shifter
Autometer Oil Psi Gauge
Autometer Trans Temp Gauge
Misc
Brand New Radiator
Cyclone Electric Fan w/ manual override switch.
New Factory Oil Psi Switch
What is the price?
Everything on this truck is in excellent condition. NADA Retail on this truck in stock form is 12,250. There is about 9-10K in aftermarket here including labor, but I want to cut a deal... I am asking NADA, $12,250 for it all.
Now on to the pics…more available upon request.
Old Jan 4, 2010 | 01:21 PM
Lucas_Harman
Bump for the new year, new lower price!
Old Jan 4, 2010 | 07:27 PM
95RAM360's Avatar
95RAM360
I just have to say that is one bada$$ ride
