Notices
FS: REC Nav Unit w map disc and antenna
Old Apr 5, 2010 | 10:31 PM
quiksilver's Avatar
quiksilver
Thumbs up FS: REC Nav Unit w map disc and antenna
I have for sale a REC Navigation Unit. Its out of a 2008 CSRT4 with only 8,000 miles so the unit looks new still. Everything works and since this is the newer model, it has the revised joystick and rear cam jack. The older versions (prior to 2007) have a tendency to break which deems the navigation useless.
Package Includes:
REC Navigation Unit P/N 5064184AF
Manual
Map Disc
What you still need:
GPS Antenna
Possibly a new Bezel
Price: $500 Shipped
This is the 2nd to the last version of the REC made. It has the revised joystick and rear camera jack.
Should work on these vehicles but I would double check before purchase:
2007-2008 Patriot
2005-2007 300C
2007 Aspen
2007-2008 Caliber
2006-2007 Charger
2006-2007 Commander
2007 Compass
2004-2007 Durango
2005-2007 Grand Cherokee
2004-2007 Magnum
2006-2007 Ram
NOTE: I'm on Caliberforums, Calibersrt4.net, and Club3g under "quiksilver".
Old Apr 9, 2010 | 12:35 AM
06diesel6spd's Avatar
06diesel6spd
Default nav unit
call me if you still have this at 818-913-xxxx Im very interested in it as long as I can use it in my 06 dodge ram truck, I would like the part # to cross reference it to make sure. Mike
Old Apr 9, 2010 | 09:03 AM
quiksilver's Avatar
quiksilver
Its 9AM est so Ill wait til about 10AM or so then I'll give you a call. I still do have it available. I'm doing the mygig conversion (and I'll be doing the swap after work). At that point, I'll be able to give you the part #.
Thanks!
Old Apr 9, 2010 | 01:38 PM
06diesel6spd
Default rec
Ill await your call Mike
Old Apr 9, 2010 | 04:30 PM
06diesel6spd
Default rec
if you want send me your #
Old Apr 27, 2010 | 12:04 PM
quiksilver's Avatar
quiksilver
Bump... changes made to post. No longer have the GPS Antenna but it does include the manual.
Old May 14, 2010 | 10:10 AM
robertog's Avatar
robertog
what is the revised price of the REC nav head now and contact me interested
Old May 24, 2010 | 03:27 PM
quiksilver's Avatar
quiksilver
Updated. $500 shipped. Replied to PM's.
