F/S 1987 V8 Dakota
F/S 1987 V8 Dakota
1987 short bed, standard cab, 2 wheel drive. Mild built 360 LA V8 with 340 X heads. Mopar M1 single plane intake. Holley 750 4 barrel carb with some mods. 727 automatic transmission with a manual reverse shift pattern vavle body with a Hurst ratchet floor shifter. Full length Super Comp headers with true dual exhaust with Flow Master mufflers. Aluminum fuel cell. New Summit Racing 3 way adjustable drag shocks, hanger and shackle lowering kit with all polly bushings for the rearend. New Jegs rims, 15x10 rears and 15x4 fronts. The rear tires are 275/60/15 Mickey T drag radials. Battery is relocated to the bed of the truck. Truck has dual electric cooling fans, and a aftermarket transmission cooler too. Theres so much more to this truck, not perfect but runs really good and fun to drive. Message me if you need more details and pics, Btbrown94@aol.com. $4,000 or trade for a Fiero GT and cash. This truck should run mid to high 12s in the 1/4 with no problems. 765-513-5039, call and or txt. Truck is located in Kokomo, Indiana.
