FS: 4.7L 68.5mm Fastman Throttle Body
This was in a 2005...website says it fits 2003-Present but as always double check to make sure it fits your engine. I used this for about 3000 miles but am selling truck now. Every now and then I put it in park and the RPM's did jump up to 1100 but it was rarely when I had this on but I wouldn't let that scare you off to it. Definitely a little snappier of the the line and has a nice little whistle sound at around 2000 RPM. On the website it asks for 180+50 core fee...I'm asking 100.00 plus shipping.
Last edited by lmrjason; Oct 21, 2011 at 02:18 PM. Reason: Cause I cant spell two good
1999-2000 Jeep have a 65mm blade and tapers to 62mm.
2000 Dodge have the same 65mm blade and tapers to a 62mm.
2001-2007 Dodge have 68mm blade that tapers to 65mm.
2001-2007 Jeep have a 68mm blade that tapers to 65mm.
1999 Jeep has a 1 year linkage type that will not work on anything else.
2000 Dodge and Jeep have identical 65mm throttle bodies.
2001-2002 Dodge have 68mm 2 screw IAC throttle bodies.
2003-2007 Dodge have 68mm 1 screw IAC throttle bodies.
2001-2005 Jeep have 68mm 2 screw IAC throttle bodies.
2006-2007 Jeep have 68mm 1 screw IAC throttle bodies.
For whatever reason Jeeps did not convert to the 1 screw IAC sensor throttle body housing for a couple years after Dodge.
The TB listed in this thread is a 1 screw IAC, will fit 2003-2007 Dodge and 2006-2007 Jeep 4.7L engines.
