Notices
FS: Flex-a-Lite 180 Black Magic E-Fan
Old Oct 21, 2011 | 02:02 PM
lmrjason's Avatar
lmrjason
Default FS: Flex-a-Lite 180 Black Magic E-Fan
This is probably one of the best e-fans you can get. 3300 cfm, Push or pull. Fit over the radiator in my 4.7L almost perfectly. I still have a few brackets that came with it. I have two small holes in the top of the fan frame/shroud I used for my custom install but there are 2 holes on each side so it is no biggie. These run for about $330.00 new. Asking $150.00 plus shipping.
Old Oct 23, 2011 | 02:00 AM
jasonw's Avatar
jasonw
Site Moderator
I used one of these for the much larger 5.9L V8 in my truck before going with a custom shroud, and it worked just fine. It should be able to cool the smaller 4.7 engines even better.
Old Oct 23, 2011 | 09:20 PM
itsUhHemi's Avatar
itsUhHemi
does this work with an any year ram?
Old Oct 24, 2011 | 01:42 AM
jasonw's Avatar
jasonw
Site Moderator
Yes it will, but I suggest putting it with your factory shroud for better air flow. Getting rid of the stock mechanical fan will get you about 1 MPG or so in town, if you can keep your foot out of the gas. It'll be hard, trust me, as you'll have a little more get-up-and-go down low.
It'll also take some custom wiring, complete with fuses and thermostat/relay.
Old Oct 25, 2011 | 12:17 AM
Brandon Anderson's Avatar
Brandon Anderson
Since you're only asking $150, I assume it does not come with the relays and thermostat?
Old Oct 25, 2011 | 02:32 PM
lmrjason's Avatar
lmrjason
I was selling my fan controller seperately...
https://dodgeforum.com/forum/parts-s...ontroller.html
Old Oct 30, 2011 | 01:21 PM
lmrjason's Avatar
lmrjason
bump bump and bump
Old Nov 5, 2011 | 12:37 PM
lmrjason's Avatar
lmrjason
one last bump before ebay
Old Nov 14, 2011 | 09:41 PM
lmrjason's Avatar
lmrjason
bumppppppppp!
Old Nov 21, 2011 | 11:23 AM
EliteTempleton's Avatar
EliteTempleton
Do you still have all this(fan, fan controller, etc) or did eBay get it?
