98 dakota manual 61k miles 4k obo
RE: 98 dakota manual 61k miles 4k obo
I printed out a carfax and it came up clean. I dont know of any collisions but I will make sure to double check the VIN and try different source than carfax. The car is running great, your welcome to come test drive it if you in the local area or region.
I'll get you the tire size when I get home, but the tires will need replacing in a few thousand miles regardless.
It was lowered via lowering control arms and a block on the back. Since then I had factory control arms and new ball bearings installed in the front and then had the blocks removed from the rear.
