Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Factory HU adding Amp and Subs
Old Apr 12, 2007 | 07:58 PM
obsesseddodge's Avatar
obsesseddodge
Default Factory HU adding Amp and Subs
can i keep the factory head unit and run a new amp to push two 2 inch subs?
2003 Ram quad cab, Infinity sound........do i need to bypass the factory amp on this install, if so....how?
Old Apr 12, 2007 | 08:03 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: Factory HU adding Amp and Subs
Of course you can. You will need what's called a Line-Out Converter. It connects to the rear speaker wires and gives you a set of RCA's for the amplifier. Some amplifiers even have high level inputs which is basically a built in LOC. And no, you do not need to bypass the Infinity amplifier for this.
