Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
dodge ram stock stereo with subs
Old May 4, 2007 | 01:50 AM
openlunchbox's Avatar
openlunchbox
Default dodge ram stock stereo with subs
first of all i would like to say hello to everybody i just joined . ok i have a 2000 doge ram 1500 extended cab and it has a infinity headunit(stock) and i am not alowed to change the headunit parents but they have agrred to let me put subs in it and mabe some after market speakers is there any way i could do this and if there is could someone tell me what i would have to buy
Old May 4, 2007 | 02:34 AM
Troy_Audi0's Avatar
Troy_Audi0
Default RE: dodge ram stock stereo with subs
Welcome..
Here is a link to another Post asking the same.. >>LINK<<
But I donot beleave he has the Infinity System..
You would need to grab the rear speaker signal from the amp input side..
Im sure some others can chime in on the amps location & what side Has the input wires..
Peace troy
Oh Whats your bugget on the Sub/Amp Combo??
Old May 4, 2007 | 02:52 AM
openlunchbox
um probobly like 200-300 mabe less im not looking to set any records
Old May 4, 2007 | 05:56 AM
habeba86's Avatar
habeba86
By the time you get proper wiring, line output converter, box, sub(s), and the amp you will be spending atleast $300 for half decent equipment. I suggest you look for an amp that has high level inputs, that way you dont have to get the line output converter...the amp has it built in, so that will save some cash.
LR Speaker +/-
brn/yel - brn/lt blu
RR Speaker +/-
blu/wht - blu/org
You can get those directly from behind the radio
Old May 10, 2007 | 06:57 PM
openlunchbox
hey can anyone point towards a website that i can buy all this stuff from and tell me what exacly i need to buy i have no idea what habeba86 was talking about i no nothing about stereos
Old May 11, 2007 | 05:33 AM
Altair's Avatar
Altair
Dak attack!
Well they're not the cheapest place but Crutchfield.com is pretty decent. They're pretty helpful if you don't know much too.
Old May 12, 2007 | 06:13 AM
habeba86's Avatar
habeba86
http://www.sonicelectronix.com/item_...AC+SNI-35.html
Since you have the factory radio, you dont have any low level outputs....only high amplified outputs. What this does is lower the voltage and give you rca outputs, so you can run rca's to the amp. But you can get amps with these built in and I suggest you get one...it will save you a few bux.
