Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
How to Install An Aftermarket CD Deck w/ Infintiy Audio system.....
Old May 10, 2007 | 02:23 AM
christrong65's Avatar
christrong65
Default How to Install An Aftermarket CD Deck w/ Infintiy Audio system.....
I have a question.... Im sure yall have heard this question a thousand times but..... I have just recently bought an 2004 Dodge Ram 1500 Quad Cab Long Bed 5.7L Hemi Laramie w/ The Infinity audio system... Well i just bought an aftermarket CD Deck and noticed that the Stock wiring harness they provided me only has wires for 4 speakers and well i have put 2 and 2 together and well figured out this was not going to work......so i called around to several places and well they came up with a few things........ (1) Completly re wire the system.......(2) Rewire the amp wires or completely disable the amp.......(3) One certain place descibed there was a certain Wire Harness for Premium Sound System......(4) I heard rumor of a wiring harness that works both with the Infinity audio system and the Steering Wheel controls..... what do yall think??? any advice is help full..... Oh and by the way once again the Dodge Dealerships that i have called ahve no clue about what i a,m talkin about so no luck there........again any help is good help.....my ideal situation would be to find the premium sound system harness that works with the Steering Wheel controls.....hopefully this is not a myth..... Thanks to everyone that helps!!!!!
Old May 10, 2007 | 08:03 PM
christrong65
Default RE: How to Install An Aftermarket CD Deck w/ Infintiy Audio system.....
well i did a little more investagating and well i found a harness @ www.metraonline.com.......... and well i am gonna see if it works and i will keep u posted on the situation....... please any info is helpful
Old May 11, 2007 | 01:17 PM
christrong65
so anybody have any info?????
Old May 12, 2007 | 06:04 AM
habeba86's Avatar
habeba86
The can-bus infinity systems suck....I havent worked on one and they seem confusing from reading everything....two ppl never say the same thing. From how I take it, you can add a radio to the non-infinity you jst have to grab acc from somewhere else for the radio. But with the infinity I dont think there is a remote turn on behind the radio for the factory amp, so idk how it gets powered on. Hopefully rt or troy might pop in here and give some more info......cuz I really have no experience with these.
Old Dec 5, 2007 | 09:46 AM
pimpd1!'s Avatar
pimpd1!
www.crutchfield.com
Old Dec 5, 2007 | 01:04 PM
PEPPERHEAD's Avatar
PEPPERHEAD
There may be some things available now but Crutchfields may be your best option. I have a 2005 Dakota with the Infinity system. Crutchfields provided the factory amp bypass when I bought my Kenwood headunit from them. You will also lose the steering wheel controls unless you buy an aftermarket control module. The module works off the HU remote. Personally I wouldn't bother as usually only certain controls will work. Not all. Hit your accessory hot on the back of the cigarette lighter which should be below the radio.
Good luck with the install.
PEPPERHEAD
Old Dec 6, 2007 | 12:09 AM
Dutch's Avatar
Dutch
Here is a link for ya for the install parts for your vehicle.
http://www.bestkits.com/SearchResult...002%20-%202005
Notice how it says Infinity radio must be relocated.
Here is a link for the picture of the Amp Bypass harness adapter
http://www.bestkits.com/ViewImage.as...=i/BHA6510.jpg
You need BHA6510 probably a special order part from any stereo shop, M.S.R.P. = $75
Try BestBuy or the like for ordering it for you.
You will also need an antenna adapter BAA20
Good Luck,
Dutch
