Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
97 Dodge Neon car alarm?
Old May 12, 2007 | 07:12 PM
Vio1's Avatar
Vio1
Default 97 Dodge Neon car alarm?
Hi, ive never had a car alarm before, and wanted to put one in. I dont have automatic door locks, is that a prob? What should i look for in terms of an alarm?
The reason I want to get one is that my car was broken into last night.
Old May 13, 2007 | 02:27 AM
das2123's Avatar
das2123
Default RE: 97 Dodge Neon car alarm?
Won't be a problem unless you want keyless entry.
Old May 13, 2007 | 04:34 AM
Vio1's Avatar
Vio1
Do alarms work if someone opens my door? or how?
I dont want to spend too much (under $60 US) what should i get?
Old May 13, 2007 | 04:48 AM
habeba86's Avatar
habeba86
Yes they go off if its armed and the doors are opened. 60 aint gona get ya much.....especially if you have it installed and I reccomened you do.
Old May 13, 2007 | 06:20 AM
Vio1's Avatar
Vio1
why would i have someone else install it? is it difficult?
Old May 13, 2007 | 01:53 PM
bad venge's Avatar
bad venge
Section Moderator
To get the proper wires attached correcty is fairly difficult and time consuming unless someone on the neon forum was nice and posted the correct wire connections and locations
Old May 13, 2007 | 03:10 PM
habeba86's Avatar
habeba86
You will need a solder gun, solder,wire stripers,a mutli meter, tape and zip ties to do the install.
Old May 13, 2007 | 07:31 PM
Vio1's Avatar
Vio1
LOOKS LIKE I WAS TOO LATE!
My car was AGAIN broken into last night, except this night they busted my drivers side window.... GREAT!
Old May 14, 2007 | 03:41 AM
habeba86's Avatar
habeba86
Looks like you need a good alarm with glass break censor.
Old May 17, 2007 | 12:27 AM
neonracer1010's Avatar
neonracer1010
park somewhere else
