Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
not sure what to do
Old Jun 11, 2007 | 11:39 PM
iamjrr's Avatar
iamjrr
Default not sure what to do
I have a 2004 Durango with the 6CD infinityhead unitand Iwant to be able to connect my xm radio and ipod to my radio without having to transmit the signal through fm frequencies. I would really like to install a new aftermarket head unit, but since the stock radio is such an odd shape, i'm worried that i would have to modify the wood trim surrounding it. plus i'm not sure if the radio is a 1 or 2 DIN. Is there a way to install a 1 or 2 DIN head unit without modifying the the trim around the stock head unit? I also looked into buying a head unit from a mopar dealer that had a front auxillary jack, but it is extremely expensive, and the head unit seems as if it will lack a lot compared to an aftermarket brand. I'm not sure as to what i should do right now and i'm wondering if you guys have options that i do not know about. Any input is greatly appreciated.
Thanks in advance....
Old Jun 12, 2007 | 04:01 AM
habeba86's Avatar
habeba86
Default RE: not sure what to do
They make dash kits that go perfectly into your dash andthere are alot of radio's with direct i-pod control and with xm also. Look into pioneer radio's.
Old Jun 12, 2007 | 07:51 PM
iamjrr's Avatar
iamjrr
Yea, I've been looking at dash kits butI cannot find one that would mold around a standard 1 or 2 din h/u. All the ones i've been looking at are molded around the odd shpaed stock h/u. Any ideas?
Old Jun 13, 2007 | 12:47 PM
rtkota5point9's Avatar
rtkota5point9
Umm... that's what you need. Any dash kit is going to mold to the factory radio opening and fit a Single or Double Din radio.
Here is the kit you need. It is a Metra Dash kit available at any stereo shop. Part #99-6507
That will fit the factory radio opening and hold a Single Din aftermarket radio.
Old Jun 13, 2007 | 07:11 PM
iamjrr's Avatar
iamjrr
Ohhh... I see what you mean. I thought you were refering to a dash kit like below...
I'll probably use that so I can replace the stock h/u and then upgrade the speakers later on.
Thanks again...
Old Jun 13, 2007 | 10:50 PM
rtkota5point9
Yeah.
If you wantedto do aDouble Din radio, you can get the Factory radio bezel for the Durangos with the factory Navigation, then get the metra dash kit 95-6510 I believe, and that will let you mount a Double-Din aftermarket radio into your dash. You canget the D-Din Bezel from the dealership, or online. Some poeple do this because Double Din radios are really nice, and they look more "factory" when done.
