Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Infinity system cd player changer.
Old Jun 30, 2007 | 05:27 PM
AtliR/T's Avatar
AtliR/T
Default Infinity system cd player changer.
Hello.
Does anyone have like a map for the wires for 2002 Stratus R/T Coupe Infinity system, with 4CD changer,?
I'm buying a DVD player to put in it's place, should there be any problems?
Here are some info about the DVD player and a picture of the inside of my Strat:
(DVD Player)
And a picture of the inside of my Strat:
With lot of thanks, Atli from Iceland (wich should explain my terrible English )
Old Jul 1, 2007 | 02:35 AM
habeba86's Avatar
habeba86
Default RE: Infinity system cd player changer.
Thats looks like a double din unit........if so.....it wont fit into your dash.
Old Jul 1, 2007 | 04:10 AM
keyboardninja's Avatar
keyboardninja
It actually looks like a single-din unit with an oversized faceplate. Alpine used to have one when they produced the CDA-7998.
Everything in your picture looks pretty standard. Are you going to use a Metra radio harness?
Old Jul 2, 2007 | 10:47 AM
AtliR/T's Avatar
AtliR/T
Metro radio harness? [&:]
Sorry, but I don't know what that is.
The DVD player is a normal Size, my friend has an "normal" alpine player and it's the same size.
So do any of you know where I can find some "blueprints" of the wires in the Infinity system (hope I'll make you understand me :P ) like wich wire is for the rear speakers, wich wire is for ground and stuff.
Old Jul 2, 2007 | 12:23 PM
rtkota5point9's Avatar
rtkota5point9
You don't need a "blueprint" or anything, just go to your local stereo shop and pick up a metra wiring harness (Part # 70-1817).
It will wire color for color to the wires on the back of your new radio, and plug directly into your cars factory wiring harness. No cutting/hacking needed. The only thing you need to remember to do is hook the BLUE wire on that harness to the Amp Turn-On wire on your new radio's harness. That will power up the factory Inifinity amp in your car.
You'll also need a dash kit to make it work. You can get that while your getting the harness as well. It's (Part# 99-6503)
or (Part# 99-6504) which is the same exact kit, with an utterly useless pocket.
Old Jul 2, 2007 | 12:28 PM
AtliR/T's Avatar
AtliR/T
Thanks alot.
I'll go out and check if I can get this somewhere here in Iceland.
