Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Stock Wiring Harness Help
Old Oct 3, 2007 | 09:35 PM
04mestrada's Avatar
04mestrada
Default Stock Wiring Harness Help
Hello everyone, i was wondering if anyone knew the stock stereo wiring harness to 2007 dodge Rampretty good and could tell me the color of a right and left speaker.
Old Oct 3, 2007 | 10:02 PM
teva_feet's Avatar
teva_feet
Default RE: Stock Wiring Harness Help
what year & model
Old Oct 4, 2007 | 06:13 PM
teva_feet's Avatar
teva_feet
if its the same as my '07 Dak......
left rear: green/blue & green/orange
right rear: grey/blue & grey/orange
left front: green & green/brown
right front: grey & grey/brown
I did find this online @ http://www.eliterides.com/tech/wirin...lor-guide.html which confuses things:
DODGE[/b]
Memory (+12v Constant) Red/White
Ignition (+12v Switched) Red
Ground (-) Black[/b] or Braided Silver Wire
IlluminationOrange
Dimmer (none)
Power Antenna Yellow
Left Front Speaker (+) Green
Left Front Speaker (-) Brown/Red
Right Front Speaker (+) Purple
Right Front Speaker (-) Blue/Red
Left Rear Speaker (+) Brown/Yellow
Left Rear Speaker (-) Brown/Red
Right Rear Speaker (+) Blue/White
Right Rear Speaker (-) Blue/Red
again, why Dodge, GM, et. al can't use the same flippin colors as the DIN/ISO standard boggles the mind
White (+) Left Front Speaker Speaker
White/Black[/b] (-) Left Front Speaker Speaker
Gray (+) Right Front Speaker Speaker
Gray/Black[/b] (-) Right Front Speaker Speaker
Green (+) Left Rear Speaker Speaker
Green/Black[/b] (-) Left Rear Speaker Speaker
Purple (+) Right Rear Speaker Speaker
Purple/Black[/b] (-) Right Rear Speaker Speaker
Old Oct 9, 2007 | 05:51 PM
mileshuff's Avatar
mileshuff
Might be easier to just purchase a wire harness adapter from your local walmart or auto stereo store. They run less than $20. Plugs into your Rams harness and has all wires labeled for connection to an aftermarket system etc. No need to cut and splice your new trucks wires.
Old Oct 9, 2007 | 11:46 PM
marionso14's Avatar
marionso14
dude just buy a harness. save you a big @$$ headache
Old Nov 17, 2007 | 02:53 PM
megacab19's Avatar
megacab19
Ok the wiring harness did not help me one bit. I did a search on the net and have not found anything about 07 Mega Cabs? Mine has the 7 speaker Infinity systam and all I want to know is the wiring diagram to and from the stock amp so that I can place in a LOC to run my amp and subs. Some one Please help me!!!!
NOTE: I am keeping the stock set-up but just adding an LOC to power my amp for my subs.
Steve
Old Nov 17, 2007 | 07:19 PM
marionso14's Avatar
marionso14
just hook up the LOC at the rear speakers then you know you have the right wires
Old Nov 18, 2007 | 11:58 AM
megacab19's Avatar
megacab19
[blockquote]
I could do that but wouldn't I need to have all four wires hooked up? I would need to tap into both sides right? I am not sure because I have not ever had to use one of these. I have always used an aftermarket HU.
Steve[/blockquote]
