Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
I had a modified engine before this one holly pistons 5mm bigger than stock chambers were cut to put
Old Dec 19, 2004 | 08:42 PM
FLYSTRATUS98's Avatar
FLYSTRATUS98
Default I had a modified engine before this one holly pistons 5mm bigger than stock chambers were cut to put
You can checkout my LED creation here too. Here is my flystratus98 years of work including new engine all done by me from system to mechanic work.
here http://www.cardomain.com/memberpage/358465
here http://www.cloudcars.org/forums/gall...545732aba61521
here http://www.cloudcars.org/forums/gall...me=album202&s=
And here http://****/gallery/showgallery.php?...0&ppuser=31348
I had a modified engine before this one holly pistons 5mm bigger than stock chambers were cut to put them in and it boost the HP to 220 according to the dyno sheet the engine lasted 3 years before it started giving me headaches so i bought a new one and replaced it. I guess I race it to hard many times over at the track. Now I have a stock engine and im going to leave it as is. The ram scoop is for apperance for now until this summer when the hood is going to be cut to put in an air intake rectangular filter and run the air through the holes of the scoop I think it will work better that way. I just ran out of time in the project is cold now. Im thinking of covering the top engine part cause the unit falls right in the scoop on the bottom when you open the hood you will see the intake and when you close the hood and drive it all the rushing air will be sucked through the scoop. Im also thinking of super charge but i have to combine the fuel air mixture propertly and is done. thanks for the interest. Peace
