Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
can ya explain this
Old Feb 27, 2008 | 10:02 PM
elitecloud's Avatar
elitecloud
Default can ya explain this
I have 2 - duel 4 ohm subs...
i want to get this amp, and will it work at 600 watts @ 2 ohms? at one channel??
FEATURES: [ul][*]1 x 600 Watts RMS @ 4 Ohms [*]2 x 300Watts RMS @ 2 Ohms [*]High End Powerful 600 watt RMS 2 channel bridgeable Amplifier [*]PWM Power Supply [*]High Speed Bi-polar Outputs [*]Regulated Power Supply [*]Fully Adjustable Crossover Networks [*]High pass filter [*]Low-Pass filter [*]By-Pass filter (No filter) [*]Variable Bass Equalizing [*]Supersonic Filter [*]Diagnostic LEDs [*]4 Gauge Power wire Connectors [*]Maxi-Fuse [*]Gold Plated Inputs and Outputs [*]Dimensions: LEGNTH: 14.88" x WIDTH: 10.39" x HEIGHT: 2.5"[/ul]
http://cgi.ebay.com/NEW-HIFONICS-ZEU...QQcmdZViewItem
that is the amp
http://cgi.ebay.com/Diamond-Audio-D6...QQcmdZViewItem
i have 2 of those already
Old Feb 28, 2008 | 09:04 AM
Dutch's Avatar
Dutch
Default RE: can ya explain this
You mean 600 Watts @ 4 Ohms
Yes, you can do this with those subs.
This amp is a 2 Channel and you want to bridge it for max power.
Wire each voice coil in Parallel, which will give you 2 Ohms per sub. Then take the Positive from each terminal on the box, and put the two positives to one channel and the negatives to the other channel on the Amp.
Its usually marked Bridged under the speaker terminals on the amp, or take a look at the manual that comes with the amp.
Regards,
Dutch
Old Mar 1, 2008 | 02:46 AM
Dutch's Avatar
Dutch
Sorry I made a mistake, must have been half asleep when I wrote that reply.
You have to runwires from one sub to the other in series, after you have parallel wired the coils on each sub.
2 + 2 wired in series equals 4 Ohms.
Regards,
Dutch
Old Mar 1, 2008 | 09:31 AM
elitecloud's Avatar
elitecloud
http://www.crutchfield.com/learningc...4%2Dohm%5Fmono
would that give 1200 watts at 2 ohms? they are dual 4 ohm subs
Old Mar 1, 2008 | 11:30 AM
squatchie16's Avatar
squatchie16
No, it would not be 1200 watts. The amp will output a max of 600. If you attempt to bridge the amp as clarified in the second post it will work. The first post will most likely cause the amp to overheat.
An alternate way, and simpler, is to wire each sub in parallel (achieving 2-Ohms each) and then wire each sub to one channel of the amp. 300x2 @ 2Ohm.
