Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
wiring lights to one switch (on, off, on)
Old Apr 12, 2008 | 07:14 PM
01dakv686's Avatar
01dakv686
Default wiring lights to one switch (on, off, on)
went to radioshack and got a rocker switch with on, off, on positions. the guy at the store said the center prong was to the lights and the other two prongs were for each power source. i'm trying to run one power from a speaker wire that way when the bass hits the lights flash but for some reason when i flip the switch the amp cuts out. what could be wrong?
Old Apr 18, 2008 | 11:50 PM
The Peddler's Avatar
The Peddler
Default RE: wiring lights to one switch (on, off, on)
You don't have the power wire from the amp hooked to the switch do you?
Old Apr 19, 2008 | 01:21 PM
01dakv686's Avatar
01dakv686
yes i do. why?
Old Apr 20, 2008 | 10:39 AM
The Peddler
You have the power run to the switch from the amp, so when you turn your switch off it will turn your amp off. Your amp needs to run to your starter, that way when you turn your car or truck on and off your amp will work with it.
