Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Show it off!!!!
Old Apr 19, 2008 | 12:03 AM
The Peddler's Avatar
The Peddler
Default Show it off!!!!
I know we have the post up top, about the system everyone has, but there was not that many pics. I want to see some pics of everbody's system, the head unit, speakers, amp, everything!! So take some pics,and show them off!!!
Old Apr 22, 2008 | 06:03 PM
DieselDemon's Avatar
DieselDemon
Default RE: Show it off!!!!
This will end up being a cool topic.
I don't have my camera till the weekend but I just installed another amp in my 95' CTD regular cab. That makes 3 amps now...lol.
Here's the layout.
Alpine CDA-9835 hu. Very, VERY durable unit. Has been flawless for almost 4 years.
Infinity 7541a 4 channel amp pushing 4 Infinity Kappa 693.7Is (6x9s, each is a 2 ohm load). Another amp that has proven well worth the money.
Audiobahn A16000V monopushing a SINGLE 10" Audiobahn Alum10Q. It thumps and I have the gain way down...lol. The sub is inbetween the driver and pass seat and fits behind the two rear mounting brackets., in a ported box. I have totally removed the center seat and console along with all the behind theseat storage.
MTX RT202. A guy had a new one and I got it for $26.00...lol. I use the MTX amp to push 4 Infinity 1011T tweeters. Two tweeters per side. You can't imagine the sounds those 4 little tweeters make...LOL!
I use an AudioPipe 1 farad and a 1.5 farad caps with the Infinity and Adudiobahn amps. The MTX also is hooked to the Infinity's cap as well. (Not that the MTX needs any stiffening to push 4 tweets.)
I have a 210 amp alt that powers it all without breaking a sweat.
The Adiobahn and Inf amps, plus both capshave 4 gauge wire from the batts. Then each amp and cap has a 4 gauge ground that mounts to seperate grounding lugs that come up thru the floor under each seat. Each ground lug has 1/0 wire from the lug, to the vehicle frame. I have a total of 8 1/0 grounds under the truck.
The MTX has 8 gauge wire for power and ground.
I don't think you could have a more solid electrical system...lol.
I will do my best to get some pics. I personally think it's the loudest, clearest, sounding system ever in a pickup truck. That is working within the confines of a regular cab. If it was extended, I'd go crazy...lol.
Hope to see other pics soon!!!!
Good luck with ALL our rides.
Old Apr 23, 2008 | 08:48 AM
The Peddler
That sounds sweeet! Can't wait to see some pics!
Old Apr 23, 2008 | 01:09 PM
fatmanajh's Avatar
fatmanajh
do ur self a favor get an optmia yellow top for the amps if you can bc those caps hold a charge untill the first time the bass hit then they take like 60 seconds to charge therefore they never really stay charged so they actualy are a marketing gimmick that actualy puts
unneeded strain on youe alt and battery not trying to talk down just making a suggestion other than that great system
Old Apr 24, 2008 | 02:48 PM
12 volt's Avatar
12 volt
alright ill play, its a little getto but works great
all start with the bass engines 2 RF P210 inch 4 OHM DVC in a home made Bandpass
next would be the power one sony 4 channel, one lightning 350RMS and a wall-mart 1 farad cap
next would be the Head unit JVC. i go this from a friend for free, he blew the preamp outputs so i took it off his hands.
it changes about every 3 months so i havent tryed toadd anything perminent. ill usally end up selling my systems to people that ride with me.
Old Apr 24, 2008 | 05:42 PM
bad venge's Avatar
bad venge
Section Moderator
Orion HCCA competition series sub powered by 2 1000 watt Crossfire 1000d's
Old Apr 24, 2008 | 08:51 PM
The Peddler
ORIGINAL: bad venge
https://dodgeforum.com/albumtn.aspx?...q209118646.jpg
That is a sweeeeeet set-up!!!!
Old May 5, 2008 | 10:28 AM
DodgeRAmPower's Avatar
DodgeRAmPower
I have no pictures currently..but i'll try to detail my truck audio system layout the best i can.
210A Mean-Green Aftermarket Alternator.
Sear's DieHard Platinum Battery. (880CCA) & a 4 year warranty
The Big 3 Upgrade. (with 0 gauge wire)
Two 6X9 Pioneer 4-way speakers in the doors.
Two 5 1/4 Infinity Kappa's in the rear panels.
Two 12" MTX 5500 series Competitionsubwoofers.
Powering the 6X9's & 5 1/4's is an Eclipse 4 channel amp. (300 watts total, 75 watts a piece) (Customed Tuned)
Powering the 12" MTX's is the 750.1 Kicker Class D Mono Block Amp. (at half gain)
Using 4 gauge Tsunami-wire throughout.
Also have a 5 Farad Cap. (This helps deliver "clean" power to your amps..reguardless what others say.)
Also using 16 gauge speaker-wire throughout.
HU is a Pioneer AVH-P4900DVD.
Hitting close to a 145 on the termlab.
Old May 5, 2008 | 04:27 PM
12 volt's Avatar
12 volt
Old May 6, 2008 | 05:13 PM
The Peddler
ORIGINAL: DodgeRAmPower
That sounds great!!! You need to get some pics up!!
