Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Removing the OEM radio 08 Ram
Old May 7, 2008 | 09:46 PM
cletus3094's Avatar
cletus3094
Default Removing the OEM radio 08 Ram
Need info on removing the bevel to replace the head unit on my 08 Ram. In the Gen 3's there were the pressure pin holes. In the Gen 4's, no pin holes! Need some info before I go crackin up my new dash board!
Help me out truckers!
Old Aug 24, 2008 | 11:10 PM
asphaltman's Avatar
asphaltman
Default radio out
me to
Old Aug 27, 2008 | 01:40 PM
Devy's Avatar
Devy
New Member
Hi !
Here you can see how to remove the oem radio on 2008 ram ..
Hope, this is what you need .
link
David
Old Sep 20, 2008 | 08:41 PM
Dodgeboy328's Avatar
Dodgeboy328
I used a couple pieces of cardboard as a backing to protect the dash and a screwdriver. It's a little easier if you start prying it off on the right side. There seems to be a little larger gap on that side. You'll probably have to get rough with it if it's the first time it's been taken off.
