Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
factory u connect system
Old Jun 24, 2008 | 11:15 PM
ml500's Avatar
ml500
Default factory u connect system
I would like to know if anyone has put a OEM U Connect System on their Dodge Ram. I have a 2006 Mega Cab with the Nav.& Infinity System without the u connect system. I also own a 2007 with Nav.and the factory installed U connect system and it is fantastic and would like to install the same system on the 2006. If anyone can steer me in the right direction it would be greatly appreciated.
Old Jun 26, 2008 | 04:22 AM
lxman1's Avatar
lxman1
Site Moderator
Default RE: factory u connect system
Try here
http://www.mopar-accessories.com/en-...ubGroupId=3025
Old Jun 27, 2008 | 10:52 AM
ml500's Avatar
ml500
Thanks for the information and link. I ordered one from Dodge yesterday.
Old Jun 28, 2008 | 10:50 PM
Rgory's Avatar
Rgory
ml500,
If your 07 has the factory installed one, the one on the link is not the factory set-up it is a Mopar aftermarket accessory that works well but is no substitute for the original. It is possible to buy the pieces and install the factory one but it takes a little money and doing.
Check out Ted here he has the only plug and play system out there. Otherwise you would have to buy the pieces and make your own custom shielded harness.
http://www.moparsupercenter.com/fact...ckspkuctr.html
