Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Help needed !!!- new stereo install
Old Jan 11, 2009 | 05:25 PM
blacklake1967's Avatar
blacklake1967
Default Help needed !!!- new stereo install
I bought a new stereo, the dash mount kit and the right harness for my '01 Caravan SE.
When I took out the factory stereo, there are 2 harnesses (as I expected), but there is also a third wire - it's white with a purple stripe, and has a white and red connector, which plugs into the factory deck...the connector is about 1" x 3/4" x 1/4"....it's a 2 pronged connector (although only uses one prong).
What is it?...please help.
PS. I know it's not the antenna, or the ground...I found those ok.
pics:
rear of factory deck (connection in question is circled.
connector in the dash...
Old Jan 11, 2009 | 08:11 PM
blacklake1967
Bump , so I can hopefully put my dash back together in the morning
Old Jan 11, 2009 | 10:22 PM
srtgtr34's Avatar
srtgtr34
You should try to find a wiring diagram for your car/truck. I installed my h/u two weekends ago and all my wires matched up to the wires on the harness adapter. My h/u came with its adapter but I assume it would be the same as an aftermarket. So if you have all the wires matched up on your harness to your stock wires then I really wouldn't worry about it. Since is definately isn't a ground or power wire, I would power the headunit up to see if everything works, If I were to guess I would say thats the mute wire, I did not hook that wire up when I did my install.
Old Jan 11, 2009 | 10:38 PM
blacklake1967
Cool...thanks very much bud, I'll finish the install in the morning...all the wires in the new unit are accounted for, so finger's crossed.
Old Jan 12, 2009 | 12:52 PM
blacklake1967
Just an update....it's all good...I'm done.
I just taped up that connection, popped in the new stereo, and it sounds fantastic...I was gonna replace all the speakers, because they buzzed with the factory system, but they sound great now, so there's an expense I won't bother with for now.
I read somewhere, that connection is a PCI Bus, whatever the hell that's for.
"Good Riddence Factory Unit" - very happy camper today!
