Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Mopar 6 disk changer install....
Old Mar 17, 2005 | 11:59 AM
Boulee's Avatar
Boulee
Default Mopar 6 disk changer install....
Last night I aquired a Mopar 6 disk changer.
Does anyone know where I can find the intstalation instuctions?
It had an owner's manual but nothing on instalation.
Although one thing I am concerned about is that the part number on the front of the manual is 82203465
and the part number listed on the mopar site is 82207483. So the changer may not work for my truck correct?
If it doesn't I'm only out $20 so I guess its not that big of deal.
Old Mar 18, 2005 | 06:22 PM
HoosierHemi's Avatar
HoosierHemi
Default RE: Mopar 6 disk changer install....
I just installed this unit my 2005 QC 4X4 1500. It took me longer to gather my tools(I first tryed a nut driver then found that a screw driver would work better) and put them away than it did to replace the current system. I'm not sure if the 2500 intererior is the same, but if it is there is a screw in the little purse hanger thing on the passenger side, remove it and you will be able to remove the center part of the dash. Then you've got 4 screws that hold the unit in and a cable and antenna. That's it. Good luck.
Mike
Old Mar 18, 2005 | 07:45 PM
Boulee's Avatar
Boulee
rock on man[sm=icon_rock.gif]
thanks for the help.
Old Apr 1, 2005 | 02:42 AM
mazz's Avatar
mazz
ORIGINAL: Boulee
$20? Man did you get a steal!!! I picked a brand new one up from a guy that had an '05 Ram, to put in my wife's Jeep Liberty, and paid $150 for it, which I was real pleased to pay.
Old Apr 1, 2005 | 12:53 PM
Boulee's Avatar
Boulee
ORIGINAL: mazz
its one of those, I know a guy who knows a guy who saw it fall off a truck or something.
I didn't ask any questions, and quite frankly I dont want to know.
Old Sep 13, 2005 | 02:35 AM
wm5e's Avatar
wm5e
I just picked up a used Mopar changer from Ebay and I was wondering what the # of the cable I need is?
I"m pretty sure that I have to buy some cable from Dodge to hook it up, right?
Thanks,
Gene
Old Oct 26, 2005 | 10:49 AM
CudaGuy's Avatar
CudaGuy
are you talking about the 6 disc in dash changer or the remote changer that mounts in the trunk or behind a seat?
The in dash changer does not need a cable. If you have the right stock head unit. The remote mounted changer will need a cable and you can probably get one at crutchfield (sp?) or at the dealer.
