Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
NEED SOME HELP QUICK
Old Feb 10, 2004 | 07:07 PM
bluedevile360's Avatar
bluedevile360
Default NEED SOME HELP QUICK
I NEED SOME ADVICE I JUST BOUGHT A 12 INCH SOLO BARRIC AN L7 I NEEDED SOME HELP ON WHAT KIND OF AMP I SHOULD GET AND HOW MANY WATTS
Old Mar 16, 2004 | 04:17 AM
Burnt 1's Avatar
Burnt 1
Default RE: NEED SOME HELP QUICK
I run a 12 in L7 also, I run a kicker KX600.1 to it.
BUT I have dual 4 ohm coils and am running it parallel into a 2 ohm load.
i was checked at a local shop and im got 740 watts running thru my sub if i keep the amp jacked up.. But i run the amp with all the settings low and she slams I tell ya...
you will wanna run around 500 to it to get a good rumble out of it...
