Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Aux in for factory RBQ
Old Dec 25, 2009 | 08:48 PM
Coaster63's Avatar
Coaster63
sorry to bring back an old thread.
Old Dec 25, 2009 | 09:03 PM
codiac's Avatar
codiac
No worries on the old thread, I use my aux in daily! It doesn't show up until you plug in that module, I only had cd, am, fm before.
Old Dec 25, 2009 | 09:28 PM
Coaster63's Avatar
Coaster63
awesome thanks for the reply. it was looking promising until i did an ebay search and only found a new converter for $74. I think ill keep looking for a used one...
Old Dec 30, 2009 | 07:11 PM
Coaster63's Avatar
Coaster63
what did you search for on ebay to find that xm box? theres only a new one on ebay if i search by the part number.
Old Dec 31, 2009 | 10:13 AM
codiac's Avatar
codiac
I bought from these guys.
http://myworld.ebay.com/esautofx
It was listed Buy It Now for $50 and I bid and won for $15 as the only bidder. Not often I bid on something no one else wants.
Old Mar 15, 2010 | 02:39 PM
brownef's Avatar
brownef
Originally Posted by codiac
So I found the 6 CD's wasn't enough and wanted to hook my Zune up, but without buying an aftermarket stereo. I didn't want to pay over $100 for the Mopar ipod hookup, so I found this Terk XMDCHY100 which is supposed to be for adding XM to your factory radio, but also has audio in for external XM devices. I found it on eBay for $15, score! It plugs into the sat. radio connector on the radio, and adds "XM" to the source list. When on XM, anything coming through the audio in plays. To take it another step, I hit up radio shack and wired my RCA's to a headphone jack, and drilled into the dash, adding an Aux in like you see on newer models!
Here's the module.
Fit's right behind the glove box next to the amp.
Audio in, as well as the XM in cable.
Radio shows "XM" and loading when I'm playing music.
Audio in on the dash blank. Could go anywhere, I had this place with nothing so I put it here. I thought about the blank next to my E cutout switch and heated seats, but this was easier, and removable.
Nice clean setup that I can put away. The alternative is to run RCA's to headphone out of the glove box, which is what I did for awhile, but it wasn't as clean, and limited my reach to as long of an RCA cable as I had. This allows me to add a really long headphone cable, for either the backseat passengers, or even out in the bed.
Here's the headphone jack from radio shack....2.99 for 2. The Terk came with an RCA you can hack up and solder on to this.
This is a great solution. I bought the box and have somebody to install it, since I didn't have a clue on how to pull the dashboard. He pluged it at the back of the radio in the empty sat radio connector, and immediately I got the "XM Radio" option when selecting Mode. connected a 3 ft cable with 2 RCA male connectors to the box, and a standard 3.5mm male connector for MP3 devices on the other end. I had to buy that cable of course. Put everything back and passed the cable into that empty space under the heater/AC controls. I plugged it onto my Garmin GPS where I have all my MP3 music, and done. 20 minutes in total, ad now I can hear all my music like if I was playing a CD. Fantastic sound, plus I can get my phone through the GPS blue tooth and the GPS directions, all through the car radio (Infinity option). Fantastic! Thank you very much.
Old Nov 7, 2010 | 08:53 PM
sparks1032's Avatar
sparks1032
Has anyone found a different way? I found the adapter but it says nothing about Dakota so mine is a 2006 with the five disc changer was wanting the 2.5 mm jack for ipod / new phone with Pandora on it!
Old Apr 4, 2011 | 04:53 PM
Robbiesworld's Avatar
Robbiesworld
Hey Codiac How do you know what wires go where on the aux jack? I notice its a 3 conductor jack and wondered how you knew what wire to solder and where. Thanks
Old Apr 4, 2011 | 04:56 PM
Robbiesworld
$49.00 + Shipping on Amazon
http://www.amazon.com/Terk-XMDCHY100.../dp/B002DV8FHE
Old Apr 6, 2011 | 06:53 PM
codiac's Avatar
codiac
On the back of the package for the headphone jack, it lists the pin assignments.
I mapped those to something I found by searching the internet. As long as whatever you solder to "right" you plug into the right audio port, you should be fine. In this case, right is 3, left is 2, and twist the grounds together on 1 (picture the headphone plug going into the socket, and where each of those would land).
