Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
help with sound system
Old Nov 30, 2009 | 04:28 PM
supraz07's Avatar
supraz07
Default help with sound system
i installed a new head unit and door speakers but still have the staticy, distortion sound that i was told was the amps conflicting but i dont see how that could still be if i replaced the door speakers. i put the stock speakers back in for now. the one flaw i can think of is maybe the amps were still conflicting cus i only put in one speaker than tested it so maybe the amp on the other speaker was messing up the new one? btw the head unit is a pioneer 4100ub and the speakers were alpine type r's 6x9
Old Nov 30, 2009 | 08:32 PM
04redmach1's Avatar
04redmach1
What year vehicle and model? Do you have them running off stock amp or aftermarket? Is it static or distortion?
Old Nov 30, 2009 | 10:15 PM
supraz07's Avatar
supraz07
it is a 2001 dodge ram 1500 with the notorious infinity sound system. the soudn is static and is only present in the front speakers even afte i replaced one. i only replaced one because i tested it after wiring th first oen adn still heard static. is it possible that the amp on the other speaker that was never removed is affecting the other speaker that i did replace?
Old Nov 30, 2009 | 10:28 PM
supraz07's Avatar
supraz07
oh and it is running off of the head unit only (or i think it is because idk about the amp on the other speaker)
Old Nov 30, 2009 | 10:56 PM
04redmach1's Avatar
04redmach1
If you hooked them up with same wires that were running stock, then they are running off stock amp.
It could be a few things:
Stock amp is going out on those channels.
Stock amp going out totally.
Distortion.
If distortion, means your bass value is too high and fade is probably towards the front more. Make sure to put your bass at 0 or neutral, and check your fade.
Where are you located?
Old Dec 1, 2009 | 02:49 PM
supraz07's Avatar
supraz07
it running off of stock wire but to run off of stock amp i thought the only amps were on the speakers unless there is another amp somewhere in the truck unless the left sepaler amp can effect the right speakers? and i am located in morris county of new jersey
Old Dec 1, 2009 | 03:30 PM
04redmach1's Avatar
04redmach1
Well, I am not sure what ohm load your factory amp is stable at. If only 8 ohm and you ran 4 ohm it could have taken a channel out. I suggest go to your local dealer and have them look.
