Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
speaker wiring
Old May 2, 2005 | 01:05 AM
RaeLynnS1's Avatar
RaeLynnS1
Default speaker wiring
PLEASE!!! I need the wiring code for 1997 Dodge Ram 1500 speakers. Thank you so much!!!!
Old May 8, 2005 | 07:32 PM
95dak318's Avatar
95dak318
Default RE: speaker wiring
I am about 75% sure that they are the same for Rams as the dakotas , but since noone else has helped you yet I guess i could try.
The speaker wire color code is as follow
(White) Left Font Speaker positive
(White/Black) Left Font Speaker negative
(Gray) Right Front Speaker positive
(Gray/Black) Right Front Speaker negative
(Green) Left Rear Speaker Positive
(Green/Black) Left Rear Speaker negative
(Violet) Right Rear Speaker positive
(Violet/Black)Right Rear speaker negative
(blue) is the power antenna
(orange/white) is for the dimmer
(Red)from ignition switch
(Yellow) 12v constant power
I hope this helps
Old May 10, 2005 | 02:13 AM
356MAGNUM's Avatar
356MAGNUM
I didnt verify out 98dak318 info but I thought I would post this website for anyone else
Wiring Diagrams
