Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Sub boxes
Old Jun 25, 2010 | 02:40 PM
  #21
nim81's Avatar
nim81
im on it. i should have just built one myself for under the seats but was lazy. i made the one for the front seat from scratch, sounds good. will post new thread when done,
sorry for hijacking OP, but some good info here
Old Jun 26, 2010 | 01:50 AM
  #22
casper3380's Avatar
casper3380
one chamber for two subs is common, wont kill the sound if the box is tuned properly.
Old Jun 26, 2010 | 09:49 PM
  #23
nozmadd0x's Avatar
nozmadd0x
IF is the key word. I would only be slightly ok with a single chamber for two subs if I made the box myself. Plus, if one sub blows it could harm the other sub where as with 2 chambers, if one sub blows the other will not be affected. The problem with trucks is they usually don't have a lot of room for extras so making a box big enough to have a port is difficult. I would just either try and buy a box or make your own but if you make your own I would say non-ported and 2 chambers.
Old Jun 27, 2010 | 10:06 AM
  #24
Nate769's Avatar
Nate769
your other option is shallow mount subs...
I'm in the process of fitting 2 pioneer shallow mounts ( 12" PORTED) into my truck. It seems that these shallow mounts need next to no room to run. I think it requires less than .5 square feet. My installer knows a little more...this is new technology, and it makes it so you can do more with a system in a truck. Cause again mine will be 12's ported!
Old Jun 29, 2010 | 12:25 AM
  #25
AF_HEMI's Avatar
AF_HEMI
shallow mount subs just sound aweful if you ask me. a shallow 12" will put out about the same quality and depth as a quality 8"
stay away from the shallow mounts if you ask me...
Old Jul 9, 2010 | 04:09 PM
  #26
wade0323's Avatar
wade0323
i made a box myself that houses one rockford fosgate 12 down firing. i built the box so it looks like my center consol! it sounds f**king awesome for 1 cheap 12.
beats so hard, my headlights rattle.
Old Jul 11, 2010 | 10:40 PM
  #27
moosefire66's Avatar
moosefire66
You guys say that having two subs sharing one space, with no divider is bad. However the fox box is built to share one space, instead of each sub having its own dedicated space... Can anyone embelish this for me? How is the fox box so great if it apparently isnt build correctly???
Old Jul 12, 2010 | 08:28 AM
  #28
Nate769's Avatar
Nate769
Its not that its not built correctly...it is a lot harder to build a 1 chamber box, that is tuned perfect. This box i am assuming is not built by your average joe, but by people who do this for their living and can calculate down to do the very square inch.
The other thing about them is that if you don't build it properly you may put strain on either or sub, if they are not ported (sealed) Which leads into another issue if both sides are not totally even volume, which in these trucks they are not, makes it that much harder...
Its much easier for an average joe to build two separate boxes, OR build one big box with chambers so it acts like 2 boxes. Personally I think 1 box with 2 ported subs (no chambers) Sounds much better then two separate boxes, hits lower IMO
