Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
ATTN: Poor Radio Sound Quality With Infinity Speakers
Old May 27, 2005 | 07:19 PM
boatbuilder's Avatar
boatbuilder
Default ATTN: Poor Radio Sound Quality With Infinity Speakers
Anyone ran into this problem on their 04 dodge Ram with the 7 speaker infinity system. This issue was brought to my attention by working w/ tech support at Infinity. I wonder if this is very pronounced issue if you have it. I mean the speakers would really have to sound horrible and be very noticeable.
DATE: March 16, 2004
SUBJECT:
OVERVIEW:
This bulletin involves correcting speaker wiring polarity in the radio connector.
MODELS:
2004 (DR) Ram Truck
NOTE : This Bulletin Applies To Vehicles Equipped With Infinity Speakers, Sales Code RCK.
SYMPTOM/CONDITION:
Radios equipped with "Infinity Speakers" may exhibit a variety of symptoms due to reversed right front speaker wiring (polarity). Symptoms include: front door or speaker buzz, poor sound quality, lack of bass.
DIAGNOSIS:
Operate the radio with the balance and fader controls to the center position. If any of the symptoms are present, perform the Repair Procedure.
REPAIR PROCEDURE:
1. Remove the radio from the instrument panel.
2. Inspect the radio connector. Cavity 8 in the connector should contain the gray with brown tracer wire and cavity 7 should contain the gray wire.
3. If the wires are reversed, remove the wires from the insulator using the appropriate terminal remover.
4. Install the gray wire with brown tracer in cavity 8 and the gray wire in cavity 7.
5. Install the radio.
