Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Head Unit Install
Old May 31, 2005 | 08:42 PM
kurtz7485's Avatar
kurtz7485
Default Head Unit Install
I searched the forum and didn't find the answer to this question.
My girlfriends father just bought a new '05 1500 Dodge Ram. He was told by best buy that the wiring harness he had used with his 1993 dodge caravan would not work with his new truck. They wanted over $100 for the hardware and install. I have installed stereo systems (headunits, amps, subs, aftermarket speakers, etc.) in my car and could easy hook up his new cd player if he trusts me to do it.....
So before I take out his old head unit etc... is it the same wiring harness and will I run into any other problems?
Also if anyone knows either of the part numbers for either harness could you please let me know.
Thanks and in the mean time I will continue searching.
Old May 31, 2005 | 08:47 PM
kurtz7485's Avatar
kurtz7485
Default RE: Head Unit Install
So far I found this that says that up to 01 rams and caravans use the same harness
Dodge Ram Pickup Car Audio
1994-2001 Dodge Ram Pickup
Dash Kit Adapter: Metra 99-6501
Stereo Wiring Harness Adapter: Metra 70-1817
Speaker Harness Adapter: Metra 72-1002
Front Speakers: 6x9 (Door)
Rear Speakers: 5.25 (Behind Seat)
1984 -1993 Dodge Ram Pickup
Speaker Harness Adapter: Metra 72-4565
Rear Speakers: None
1998-2001 Dodge Caravan/Grand Caravan
Car Stereo Dash Adapter: Metra 99-6504
Speaker Wiring Harness Adapter: Metra 72-5510
Front Speakers: 5.25 (Dash); 5x7 (Front Door, Optional)
Rear Speakers 6x9 (Mid Panel)
1984-1997 Dodge Caravan/Grand Caravan
Car Stereo Dash Adapter: Metra 99-6501
Rear Speakers: 6x9 (Tail Door)
Old May 31, 2005 | 09:00 PM
kurtz7485's Avatar
kurtz7485
I think the '05 ram 1500 use the
Metra 70-6502
but Im not sure because the only sites I see only go up to 02 rams....
So If I get this harness that should be all there is to it...???
Old May 31, 2005 | 09:37 PM
ngsm13's Avatar
ngsm13
As stated, they do not use the same harness. Just walk into a local shop, and ask for a wiring harness for the desired vehicle...it'll be less than $20 (I usually pick wiring harnesses up for around $10-15). Then that's all you need, just take off the dash part, plug the aftermarket wiring harness into the stock harness...and bam...match color-coded wires. If he has any type of premium stock system, like with a stock amplifier, you will need to make sure it will still have a remote turn-on. later
NG
Old May 31, 2005 | 10:04 PM
kurtz7485's Avatar
kurtz7485
Thanks NG,
Thats what I figured.
Kurtz7485
