Agreed, if you have no power to the head unit then you need to recheck those fuses. If they are good then you need to check for voltage on that HU. If there is voltage there but it isnt coming on then make sure there is no fuse on the back of the HU. Make sure you still have a ground also. The amp will not come on because the HU controls the remote amp wire.
