High Output Alternator
Anyone running a ho alternator? I have a 4.7, not sure if the bolt pattern is the same as the 5.7 but some brand names would help. Looking for something under $400 with atleast 100 amps at idle and atleast 200 max under 1500 rpm. www.powerbastards.com sells one for $300 with good power but I don't know if it will fit. If it would, it would have to be side ways. Will be running a 15 or 2 with atleast 2000 watts rms so alt and aux batt will be almost necessary.
Im running 2 12s with right at 2k watts, 5 TV's, an xbox 360, 200 watt power inverter (for the laptop) and a Viair 380C air compressor. Im going to add another 12 and another 600-800 watt amp here soon when I finish my custom center console. I also run 2 sets of HIDs.
I run all of this off my stock 136 amp alt and two 1000CA batteries. I do have the Big 3 done to all my power and ground wires.
So are sure you need a bigger alt?
However, if you are set on having one, check with Joe Fox at www.foxacoustics.com as he is the only one I know with an HO alt.
