Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
After market NAV system intall??
Old Dec 25, 2010 | 06:10 PM
tonkabilly's Avatar
tonkabilly
Ya I am not too sure on this one. Manual states that it for when the deck receives a negative pulse when your cell goes off it will automaticaly mute the deck. Only problem is the truck harness does not have this.
Old Dec 25, 2010 | 10:38 PM
CaliDodgeRam's Avatar
CaliDodgeRam
Ya man I have never heard/seen one of those and I have probably put in 5-10 double din's as well as countless single dins.
Old Dec 26, 2010 | 12:49 AM
tonkabilly's Avatar
tonkabilly
Try and get it installed in the next day or two and will advise as to what happens. Thanks for the help
Old Dec 27, 2010 | 01:43 AM
CaliDodgeRam
Let us know.
Old Dec 27, 2010 | 01:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I had an old Pioneer HU that you could use a toggle switch to trick the HU into thinking the e-brake has been applied. My newer HU does need that switch but another wire is grounded instead. So it all depends on the HU
Old Dec 28, 2010 | 07:23 PM
tonkabilly's Avatar
tonkabilly
Got it all hooked up and runs awesome. I went with the relay and works perfect. Didn't bother with the brown wire and cell calls come in perfect. Thanks for the help.
Old Dec 29, 2010 | 09:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Glad you got it all install? Any pics?
Old Dec 29, 2010 | 09:48 PM
CaliDodgeRam
Good to hear man, but ya as said above we get off on pics around here haha let us seee
Old Dec 29, 2010 | 10:59 PM
tonkabilly's Avatar
tonkabilly
I will see what I can do for you...... Ran into one problem today. Looks like I have to hook up the VSS wire. GPS works great as long as all I want to see is my home address. Will not update as I drive. Only stays at home. Problem is I have no clue where to hook up this wire on my truck. (2006 3500 mega cab diesel) Any help on this one would be great.
Thanks guys
Old Dec 30, 2010 | 08:03 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Its going to be at the ECM/PCM harness but I need to know if you have a HEMI or CTD so I can look it up for you and tell you where and which one it is
