Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
PAC C2R-CHY4 Can Bus Reverse Wire Question
Old Jan 22, 2011 | 03:27 PM
callen9345's Avatar
callen9345
Default PAC C2R-CHY4 Can Bus Reverse Wire Question
The CAN BUS has a Green Reverse Output wire that is supposed to be connected to the stereos Reverse Gear wire (trigger wire). My question is; can I connect the camera's positive wire to the CAN BUS reverse wire too? Or do I need to connect it to the reverse lights directly. Seems to me that if the Can Bus has a reverse wire, that I should be able to connect this to the camera as well rather than running a seperate connect ot the actual reverse lights. Unless the Can Bus wire does not supply enough amperage or something.
Help!
Old Jan 22, 2011 | 03:35 PM
dirtydog's Avatar
dirtydog
Moderate User
For a back-up camera installation, you need to locate the white/lt green stripe wire between the battery and firewall. That is the reverse signal.(always check with a volt meter before tapping ANY wire) You MUST connect the power wire to CONSTANT 12v+ or you will have issue's with your camera working.
So if you have a Nav unit your hooking up, the NAV unit ties into the reverse wire and the camera itself ties into the 12v+ constant.
Old Jan 22, 2011 | 04:12 PM
callen9345's Avatar
callen9345
Thank you for the reply!
Should I connect to 12v constant or 12v accessary. I am just concerned that if I connect to 12v constant the camera will always be on draining the battery.
Old Jan 22, 2011 | 09:53 PM
lxman1's Avatar
lxman1
Site Moderator
12v Accessory.
