Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
OEM HU swap w/ VES
Old Jun 16, 2011 | 09:23 AM
spande's Avatar
spande
Default OEM HU swap w/ VES
I am new to this forum, and have done some research on this site, as well as on the web - all with not much success.
> My issue is that my 2005 Durango has the 6cd changer w/ infinity system and a factory rear dvd system (VES). The cd changer stopped working (jammed), which is a problem I had in another vehicle that was repaired, unfortunaltey, the mopar unit was not repairable. The radio and VES still work.
> What I would like to do is to swap out the HU with another chrysler/dodge units I have found on ebay or websites. I am unsure if what i have found on ebay will work for me. My unit is a model number P05091720AE (RAQ). It has 2 connectors on the back and a cooling fan on the side. If I can, I would prefer to have a singe cd player with an aux out for an ipod connection, but I still want the DVD player to operate and I was hoping to keep the infinity amps since the system overall sounds pretty good to me.
> I went to my dealer, and they were friendly, but not able to help out very much. They were not to able to tell me the difference b/w several models and whether the dvd would work, and they were unsure of what RAQ, REF etc. meant. A new replacement unit is over $600.
> Thanks in advance for any insights/suggestions anyone can offer.
Old Aug 31, 2011 | 11:32 PM
VenusDoom88's Avatar
VenusDoom88
spande,
I wish I could help. I just recently joined this forum just for this specific issue! I have a 2005 Durango with the REF unit and I am having issues with an aftermarket iPod auxiliary connection. The connection keeps shorting out and I have to keep pulling the head unit's fuse and put it back in just so the iPod auxiliary will play. I select the iPod through the MODE button and it uses the SAT feature because I don't have satellite radio. When it shorts out, the MODE button doesn't work and the SAT option isn't even available.
To make a long story short, the dealer where I had it installed replaced the iPod auxiliary setup twice and it still has the same problem. So, I am looking to replace the entire REF factory unit with a newer 2006 REF model with the auxiliary cord attachment on the outside.
I've done all the research and still no luck. I wish someone knew if these radios could just plug in and work. Until then, I will keep researching.
