Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Sub for foxbox
Old Jul 21, 2011 | 09:09 AM
rckjp63's Avatar
rckjp63
Default Sub for foxbox
Can anyone reccomand a good sub for the 12" single foxbox.
I allready have an amp that I took out of my jeep.
It is a Infinity 1600a - 400 watts x 1 channel at 4 ohms/
600 watts x 1 channel at 2 ohms.
Thanks
Old Jul 21, 2011 | 12:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im running Kicker CVR 12s in my FB
Old Jul 22, 2011 | 01:02 PM
rckjp63's Avatar
rckjp63
Weedahoe would a single Kicker CVR work with the amp I have,
Aren't they dual voice coil.
Old Jul 22, 2011 | 01:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
One kicker cvr 12 is rated at 400 continuous or 800 max so what you have is fine.
Old Jul 22, 2011 | 02:50 PM
rckjp63's Avatar
rckjp63
Thanks Weedahoe. One more question, Would wire that in series or parallel.
Old Jul 22, 2011 | 05:05 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you have a single sub with 4 ohm DVC then run it parallel. If it is 2 ohm DVC then run it series.
