Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Wiring for 03 RAM 1500
Old Aug 16, 2011 | 11:22 PM
bandroidx's Avatar
bandroidx
Default Wiring for 03 RAM 1500
hey all, i am looking for wiring colors for the ignition harness on a dodge ram 1500 - 2003. I found 2004 wiring on 12volt forums but its not the same at all.
thanks
Old Aug 17, 2011 | 01:04 AM
bandroidx's Avatar
bandroidx
i found this for an 02 and it looks much closer to mine than the 04.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|pnk/blk & red/wht |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|blue (16 awg) |+ |ignition harness |
| SECOND IGNITION|red or red/wht |+ |ignition harness |
| ACCESSORY|green & orange |+ |ignition harness |
| SECOND ACCESSORY|blue & blk/wht *7 |+ |ignition harness |
| POWER LOCK|white/green *1 |- |driver kick panel |
| POWER UNLOCK|same wire | | |
| LOCK MOTOR|tan/pnk or tan/blk | |driver kick panel |
| UNLOCK MOTOR|blue | |driver kick panel |
| DISARM DEFEAT|tan/white | |passenger kick panel |
| PARKING LIGHTS +|black/yellow | |relay under hood at pwr ctr |
| PARKING LIGHTS -|purple/yellow *2 | |headlight switch |
| HEADLIGHTS|purple/yellow *2 |- |headlight switch |
| DOOR TRIGGER|*3 |- |*3 |
| DOME SUPERVISION|use door trigger | | |
| FCTRY ALARM ARM|lt green/orange *4 |- |driver kick panel |
|FCTRY ALRM DISARM|same wire | | |
| DISARM NO UNLOCK|same wire | | |
| TACHOMETER|NOT green/orange | |ign coil, coil pac, injector|
| SPEED SENSE|white/orange | |wht conn. 2, pin 27 @ PCM *5|
| BRAKE WIRE|white/tan |+ |brake pedal switch |
| HORN TRIGGER|black/red |- |steering column |
| WIPERS|brn/wht(L),rd/yel(H)|+ |wiper motor |
| LF WINDOW UP/DN|lt blue - white |A |driver window switch |
| RF WINDOW UP/DN|brn/wht - pur/wht |A |driver kick panel |
| LR WINDOW UP/DN|red/blk - blu/wht |A |driver kick panel |
| RR WINDOW UP/DN|grn/wht - gry/blk |A |driver kick panel |
| RADIO 12V|pink |+ |radio |
| RADIO GROUND|black/green |- |radio |
| RADIO SWITCH|brown/red |+ |radio |
| RADIO ILLUMINATE|orange/blue (dimmer)|+ |radio |
| LF SPEAKER|lt grn/rd-lt grn/grn| |radio or amplifier *6 |
| RF SPEAKER|lt blu/pu-lt blu/blk| |radio or amplifier *6 |
| LR SPEAKER|wht/red - wht/blk | |radio or amplifier *6 |
| RR SPEAKER|tan/pur - tan/blk | |radio or amplifier *6 |
Notes:
NOTE: For the 2002 Ram 2500/3500, refer to the 2001 techsoft sheet. NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays. *2 Parking lights require a negative trigger thru a 330 or 1.4K ohm resistor. Headlights require a negative trigger thru a 1.8K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. *3 The LF door trigger is tan, and the LR door is tan/orange or purple/orange. These wires are in the driver kick panel. The RF door trigger is tan/red, and the RR door is tan/yellow. These wires are in the passenger kick panel. Use all wires and diode isolate each. See directfax document #1076 for wiring information. *4 This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays. *5 The PCM (Powertrain Control Module) is on the passenger side firewall. *6 The amplifier is located behind the glove box. *7 These wires may not be necessary for remote start.
anyone have anything else to compare?
Also i am looking for the reverse light trigger, i know its in the driver kick panel but a color would help for sure. thanks
Old Aug 17, 2011 | 01:14 AM
bandroidx's Avatar
bandroidx
Ok i found another post saying it didnt change from 2002 to 2003 so I think that is correct for future reference.
I need power for my new power window kit, i was considering tapping the 2nd accessory or 2nd ignition. the kit has a 30amp fuse inline but i doubt they draw that much.
Old Aug 17, 2011 | 01:40 AM
bandroidx's Avatar
bandroidx
Also i have a thick green cable but its not in the chart, could that be a ground?
EDIT: i think the green had 12v at some point when i was probing though, so maybe not.
Old Aug 19, 2011 | 08:43 PM
dirtydog's Avatar
dirtydog
Moderate User
There is more than likely 3 ignition wires.(hot-run)(2x-hot-acc) All 10ga wires off the Ign are likely 12v supplies. Green could be your heater controls?
wedahoe has wiring diagrams downloadable via his sig and/or the faq section
Old Aug 23, 2011 | 12:56 AM
bandroidx's Avatar
bandroidx
thanks the green was the 3rd ignition (for heater blower) and I tapped that for my power windows and it seems to work well.
there are several red / whites, one thin one is 12v+ so i used that for my auto dimming mirror, and there is a black/white that is accessory that i tapped for the auto dimming mirror too.
atleast now i know what all the wires are and it should make it easier to install a remote start soon.
Old Aug 23, 2011 | 03:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
i remember when i did my full alarm and remote start and although i got it done, it was a pita.
Old Nov 1, 2013 | 04:26 AM
bandroidx's Avatar
bandroidx
I am finally getting around to installing the remote start. LOL been a while. Do you recall what was a PITA?
Old Nov 1, 2013 | 04:28 AM
bandroidx's Avatar
bandroidx
Also, any idea what this means for the tach wire? | TACHOMETER|NOT green/orange | |ign coil, coil pac, injector|
NOT green/orange?? confusing.
It's been over 10 years since I used to install these, how can I make sure I have the right wire for the tach wire, iirc its an AC wire.
Old Nov 1, 2013 | 09:18 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Door locks were a PIMA
Tach were on the alarm module goes to one of the two wires on #8 spark plug coil. One wire is an ASD (Auto Shut Down) wire and the other is the 12v wire.
You want the 12v wire
