Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Ipod Nano error
Old Apr 28, 2012 | 01:07 PM
southpaw959's Avatar
southpaw959
Default Ipod Nano error
I keep getting an error when I try and connect my iPod Nano 6th gen to the radio. Can anyone help??
Old Apr 28, 2012 | 04:01 PM
saberworks's Avatar
saberworks
I wasn't able to get my shuffle to work correctly in the glove box usb port. I hooked it up to the front and the radio downloaded all of the songs.
Old Jun 3, 2012 | 11:57 AM
southpaw959
Nope that did not work either. I am going take it to the dealer since the it will not download anything from a CD or USB drive either. I can not get pictures or anything to go to the hard drive.
Old Jun 7, 2012 | 02:16 PM
MattsMountain's Avatar
MattsMountain
You may want to check for the radio software upgrade. Pretty easy to do and seems to have cleaned up a few issues I was having.
Old Dec 13, 2012 | 05:10 AM
MicleArons's Avatar
MicleArons
there is a guy on EBAY that makes very nice clean SIMPLE and inexpensive mounts for Ipods...it attaches using an existing bolt on your ...
Old Dec 13, 2012 | 07:22 AM
xsdbs's Avatar
xsdbs
What year is the vehicle & do you know the build date?
If it's a 2011 built prior to 6-1-2011 then there is a Uconnect SW update available. The dealer can perform i under TSB 08-019-12. It is also available for you to do yourself if you'd like to. It's a simple update.
Old Dec 13, 2012 | 07:25 AM
xsdbs's Avatar
xsdbs
The Shuffle is not a compatible item to Uconnect. Other Ipods/ IPhones will not work from the radio mounted USB connector. Nor will you be able to download your music from the Apple device to the radio HD.
