Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Question on head unit upgrade
Old May 31, 2012 | 02:29 PM
tbo1004's Avatar
tbo1004
New Member
Default Question on head unit upgrade
I have recently purchased a 2012 Ram 1500 Quad Cab Express. It came with the lowest end stereo (the 130 I think). I am looking at upgrading to a double DIN JVC KW-AV60BT. Crutchfield and Amazon recommend this.
My question is, is this expensive an adapter necessary? It says it "retains warning chimes, etc....
Is it really worth $50 more than a standard wiring harness?
Thanks
Old May 31, 2012 | 04:39 PM
Moltenburn's Avatar
Moltenburn
The harness is not necessary but I have heard it makes the install much easier. the reason being no need to hack factory wiring and it helps add a 12V source which your Ram's current audio harness does not have. I am planning a upgrade in my DAK but also will end up needing this harness. You can get them on amazon for a bit cheaper I do believe.
Old Jun 1, 2012 | 09:55 AM
Shawn Selzer's Avatar
Shawn Selzer
Moltenburn is right! ues the pac interface dont go with the metra it will caues problums with sound quality in your truck.
